imx6ull の無線なしを使用しています。
systemctl is-enabled wpa_supplicantがdisabledにもかかわらず、
軌道時にデーモンがスタートする。maskしないとダメか?
I’d be glad to help with your wpa_supplicant daemon issue! To provide the most accurate guidance, could you let me know which OS and version you are using?
For example, are you using:
- Torizon OS (and which version?)
- Yocto BSP (and which version?)
You can get this information by running the tdx-info command on your device. More details about this command can be found at: https://developer.toradex.com/software/development-resources/tdx-info/
Background Information
The Colibri iMX6ULL comes in several variants, including versions without Wi-Fi(1). If you’re using a non-Wi-Fi version but wpa_supplicant is still starting, this could be due to:
- Default system configuration - The service might be enabled by other mechanisms
- Dependency chains - Other services might be triggering wpa_supplicant startup
- Socket activation - systemd might be starting the service on-demand
Potential Solutions
While I wait for your OS version details, here are some general approaches:
Option 1: Masking the Service
sudo systemctl mask wpa_supplicant
Option 2: Check for Socket Units
systemctl list-units --type=socket | grep wpa
Option 3: Review Dependencies
systemctl list-dependencies --reverse wpa_supplicant
Once you provide your OS version information, I can give you more specific guidance tailored to your exact setup.
