Hi team,
A customer is trying to workaround the Ethernet PHY issue while keeping the availability of enabling/disabling the networking access dynamically. For that, instead of changing the access at PHY level with ip link set eth0 down
, they came up with a similar measure but at IP level by changing the route tables and discarding/accepting all packets:
# Enabling networking access
iptables -P INPUT ACCEPT
iptables -P FORWARD ACCEPT
iptables -P OUTPUT ACCEPT
# Disabling networking access
iptables -P INPUT DROP
iptables -P FORWARD DROP
iptables -P OUTPUT DROP
At the end, what the customer wants is to disable any remote access by all means. I think myself it is a good workaround but I wanted to confirm with you. Do you see any issue with this approach?
Thanks and best regards,
Alvaro.
