I have bought a Colibri iMX6S and have replaced its OS from a Linux to the WinCE7. I believe I got certainly success to install by referring the post about iMX6 WinCE Bring-up. But I have found that the USB-Connection by the Windows Mobile Device Center does not work at all. I know it is established automatically against the Colibri VF50, and I think it is quite required for debugging on the Visual Studio.
I wonder if you could give us something good solution as possible as you can. thank you.
This issue has been fixed and USB client connectivity will work on i.MX6S with the next release of the OS that should be released in a few weeks.
In the meantime (and in the future, if this is simpler for you than using the USB connection) you may use ethernet for debugging:
