I’m facing an issue where some Colibri modules don’t autocopy the folder as that they should. I have the following:
- Iris Board Rev 1.1
- Coibri IMXDL on versions 1.1A and 1.0A
- USB Drive with Custom Windows EC7 image, containing:
a. Custom Registry
b. Custom Config
c. Autocopy Folder, contaning my application
d. Toradex Easy Installer files
Out of 9 Colibri modules, I’ve faced this issue on 2. I have used the same USB Drive on all modules and the same Iris Board for the following process:
- Boot the module on recovery mode
- Recover the module to start TEZI
- Select the Custom Image on the USB drive
- After reflashing the module, reboot the Iris Board with Reset button (with the USB drive still connected)
- Restart, with Windows set up
- Wait until the Autocopy features complete
With the 7 modules that run OK, the process is just fine: I wait until it copies everything to Flashdisk and restart the board with my application. With the 2 bad modules, Windows starts but the Autocopy never finishes: some files are copied but not everything, that holds me from running my application
What can be happening? From those 2 bad modules, one is on V1.1A and the other one is on V1.0A
