When I connect the colibri imx6 to a windows 10 computer , the Colibri is detected but with the message “Unknown USB Device(Device Descriptor Request Failed)”
Why and How I can solve that?
Dear @NIzar11081976,
Do you have multiple USB hubs between the module and your host machine?
Kevin
@kevin.tx : Hi , No hub between the HOST machine (a PC or Laptop) and the Colibri Board.
Regards Nizar
Could you please specify:
Your Colibri iMX6 full name and HW version
OS you are running and its BSP version
Carrier board you are using and its HW revision
What USB slot you are using to connect to Windows 10?
Have you installed any extra USB drivers or done some OS tweaks related to USB settings?
- Colibri imx6 DL 512MB V1.1A
- WEC2013
- We are using our own carrier Board (the ref for our dev was the Colibri Evaluation Board. the difference is that we have USB-A and USB-B connector connected to the USB OTG)
- What do you mean by USB slot?
- No extra drivers .
As mentionned the test was done on a laptop and a desktop with windows 10 Enterprise.
Multiples tests were done with a help of this page USB Function Driver (WinCE) | Toradex Developer Center
Could you please provide a WEC2013 BSP version? You can get it starting “Update Tool” and click on “Version Info” button.
Have you tried to use another USB cable and/or Windows box?
We are using the 1.06 version of the BSP
Do you mean 1.6?
Sorry. Yes 1.6.
I have not tried another USB cable. As mentionned in previous comments I tried with a windows laptop and a windows desktop.
Problem solved. This was due to our hardware design.
Glad you problem was solved. Thanks for the update.
