Hi, thanks a lot for your work and for the Windows IoT Core Starter Kit. I’m playing with it and it looks very promising. I would like to ask you the following:
- When do you plan to add VGA support (1024x768 resolution), currently only HDMI and DVI is the option
- When do you plan to add RS232 support (RX-TX only can be the base)
Thanks in advance
Mirco Vanini
