…it just did. After getting disconnected from 192.168.178.94, which is the tablet’s IP in the WLAN (network interface uap0) and getting ssh: connect to host 192.168.178.94 port 22: Connection timed out trying to reconnect via ssh, I connected the tablet via ethernet, ssh’d onto it via the LAN IP 192.168.178.89 and looked at the last 500 lines of journalctl, this should be the relevant parts where the WiFi connection drops up until I get an ethernet connection:
journalctl excerpt
Jan 30 13:07:14 colibri-imx8x-07329158 systemd-networkd[724]: uap0: Link DOWN
Jan 30 13:07:14 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242434.1148] device (uap0): set-hw-addr: set MAC address to 0E:10:47:42:EC:A5 (scanning)
Jan 30 13:07:14 colibri-imx8x-07329158 systemd-networkd[724]: uap0: Link UP
Jan 30 13:07:14 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242434.1206] device (uap0): supplicant interface state: disconnected -> interface_disabled
Jan 30 13:07:14 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242434.2254] device (uap0): supplicant interface state: interface_disabled -> inactive
Jan 30 13:07:39 colibri-imx8x-07329158 wpa_supplicant[872]: uap0: Reject scan trigger since one is already pending
Jan 30 13:08:56 colibri-imx8x-07329158 sshd[1732]: Timeout, client not responding from user torizon 192.168.178.29 port 61444
Jan 30 13:08:56 colibri-imx8x-07329158 sshd[1719]: pam_unix(sshd:session): session closed for user torizon
Jan 30 13:08:56 colibri-imx8x-07329158 systemd[1]: sshd@0-192.168.178.94:22-192.168.178.29:61444.service: Deactivated successfully.
Jan 30 13:08:56 colibri-imx8x-07329158 systemd[1]: session-c1.scope: Deactivated successfully.
Jan 30 13:08:56 colibri-imx8x-07329158 systemd-logind[697]: Removed session c1.
Jan 30 13:08:59 colibri-imx8x-07329158 sshd[2443]: Timeout, client not responding from user torizon 192.168.178.29 port 59900
Jan 30 13:08:59 colibri-imx8x-07329158 sshd[2441]: pam_unix(sshd:session): session closed for user torizon
Jan 30 13:08:59 colibri-imx8x-07329158 systemd[1]: sshd@2-192.168.178.94:22-192.168.178.29:59900.service: Deactivated successfully.
Jan 30 13:08:59 colibri-imx8x-07329158 systemd[1]: session-c3.scope: Deactivated successfully.
Jan 30 13:08:59 colibri-imx8x-07329158 systemd-logind[697]: Removed session c3.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1]: Stopping User Manager for UID 1000...
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Activating special unit Exit the Session...
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Stopped target Main User Target.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Stopped target Basic System.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Stopped target Paths.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Stopped target Sockets.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Stopped target Timers.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Closed D-Bus User Message Bus Socket.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Removed slice User Application Slice.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Reached target Shutdown.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Finished Exit the Session.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1726]: Reached target Exit the Session.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1727]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[<unknown>] user=[torizon] ruser=[<unknown>] rhost=[<>
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1]: user@1000.service: Deactivated successfully.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1]: Stopped User Manager for UID 1000.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1]: Stopping User Runtime Directory /run/user/1000...
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1]: run-user-1000.mount: Deactivated successfully.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1]: Stopped User Runtime Directory /run/user/1000.
Jan 30 13:09:09 colibri-imx8x-07329158 systemd[1]: Removed slice User Slice of UID 1000.
Jan 30 13:10:57 colibri-imx8x-07329158 systemd-timesyncd[675]: Timed out waiting for reply from 216.239.35.4:123 (time2.google.com).
Jan 30 13:11:07 colibri-imx8x-07329158 systemd-timesyncd[675]: Timed out waiting for reply from [2001:4860:4806:4::]:123 (time2.google.com).
Jan 30 13:11:49 colibri-imx8x-07329158 kernel: usb 1-1.2.1.4: new high-speed USB device number 9 using xhci-hcd
Jan 30 13:11:49 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242709.7364] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/15)
Jan 30 13:11:49 colibri-imx8x-07329158 kernel: ax88179_178a 1-1.2.1.4:1.0 eth0: register 'ax88179_178a' at usb-xhci-hcd.1.auto-1.2.1.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, 00:0e:c6:a0:54:e0
Jan 30 13:11:49 colibri-imx8x-07329158 kernel: usbcore: registered new interface driver ax88179_178a
Jan 30 13:11:49 colibri-imx8x-07329158 systemd-udevd[3030]: Using default interface naming scheme 'v250'.
Jan 30 13:11:49 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242709.8099] device (eth0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jan 30 13:11:50 colibri-imx8x-07329158 systemd-networkd[724]: eth0: Link UP
Jan 30 13:11:50 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242710.1871] settings: (eth0): created default wired connection 'Wired connection 1'
Jan 30 13:11:52 colibri-imx8x-07329158 ModemManager[688]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/bus@5b000000/5b110000.usb/5b130000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.2/1->
Jan 30 13:11:52 colibri-imx8x-07329158 kernel: ax88179_178a 1-1.2.1.4:1.0 eth0: ax88179 - Link status is: 1
Jan 30 13:11:52 colibri-imx8x-07329158 systemd-networkd[724]: eth0: Gained carrier
Jan 30 13:11:52 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242712.5347] device (eth0): carrier: link connected
Jan 30 13:11:52 colibri-imx8x-07329158 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jan 30 13:11:52 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242712.5391] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Jan 30 13:11:52 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242712.5435] policy: auto-activating connection 'Wired connection 1' (444bcea7-7d1b-3ef5-a276-33d81c34b9e0)
Jan 30 13:11:52 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242712.5472] device (eth0): Activation: starting connection 'Wired connection 1' (444bcea7-7d1b-3ef5-a276-33d81c34b9e0)
Jan 30 13:11:52 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242712.5480] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jan 30 13:11:52 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242712.5509] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jan 30 13:11:52 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242712.5555] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jan 30 13:11:52 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242712.5588] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Jan 30 13:11:52 colibri-imx8x-07329158 avahi-daemon[796]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9f56:9b10:85fb:52d3.
Jan 30 13:11:52 colibri-imx8x-07329158 avahi-daemon[796]: New relevant interface eth0.IPv6 for mDNS.
Jan 30 13:11:52 colibri-imx8x-07329158 avahi-daemon[796]: Registering new address record for fe80::9f56:9b10:85fb:52d3 on eth0.*.
Jan 30 13:11:52 colibri-imx8x-07329158 kernel: IPv4: martian source 192.168.178.94 from 192.168.178.29, on dev eth0
Jan 30 13:11:52 colibri-imx8x-07329158 kernel: ll header: 00000000: ff ff ff ff ff ff 44 e5 17 a7 9a f4 08 06
Jan 30 13:11:53 colibri-imx8x-07329158 kernel: IPv4: martian source 192.168.178.94 from 192.168.178.29, on dev eth0
Jan 30 13:11:53 colibri-imx8x-07329158 kernel: ll header: 00000000: ff ff ff ff ff ff 44 e5 17 a7 9a f4 08 06
Jan 30 13:11:54 colibri-imx8x-07329158 systemd-networkd[724]: eth0: Gained IPv6LL
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.5503] dhcp6 (eth0): activation: beginning transaction (timeout in 45 seconds)
Jan 30 13:11:54 colibri-imx8x-07329158 avahi-daemon[796]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9f56:9b10:85fb:52d3.
Jan 30 13:11:54 colibri-imx8x-07329158 avahi-daemon[796]: Joining mDNS multicast group on interface eth0.IPv6 with address 2001:16b8:cbc8:8700:4d98:697:3dfd:6973.
Jan 30 13:11:54 colibri-imx8x-07329158 avahi-daemon[796]: Registering new address record for 2001:16b8:cbc8:8700:4d98:697:3dfd:6973 on eth0.*.
Jan 30 13:11:54 colibri-imx8x-07329158 avahi-daemon[796]: Withdrawing address record for fe80::9f56:9b10:85fb:52d3 on eth0.
Jan 30 13:11:54 colibri-imx8x-07329158 avahi-daemon[796]: Registering new address record for fd85:9c4d:89d5:0:522b:f0c8:bcc6:324e on eth0.*.
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.5579] dhcp6 (eth0): state changed new lease
Jan 30 13:11:54 colibri-imx8x-07329158 dbus-daemon[689]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=>
Jan 30 13:11:54 colibri-imx8x-07329158 kernel: IPv4: martian source 192.168.178.89 from 192.168.178.1, on dev eth0
Jan 30 13:11:54 colibri-imx8x-07329158 kernel: ll header: 00000000: 00 0e c6 a0 54 e0 48 5d 35 01 55 a5 08 00
Jan 30 13:11:54 colibri-imx8x-07329158 systemd[1]: Starting Network Manager Script Dispatcher Service...
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.5978] dhcp4 (eth0): state changed new lease, address=192.168.178.89
Jan 30 13:11:54 colibri-imx8x-07329158 avahi-daemon[796]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.178.89.
Jan 30 13:11:54 colibri-imx8x-07329158 avahi-daemon[796]: New relevant interface eth0.IPv4 for mDNS.
Jan 30 13:11:54 colibri-imx8x-07329158 avahi-daemon[796]: Registering new address record for 192.168.178.89 on eth0.IPv4.
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.6241] policy: set 'Wired connection 1' (eth0) as default for IPv4 routing and DNS
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.6261] manager: NetworkManager state is now CONNECTING
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.6270] policy: set 'Wired connection 1' (eth0) as default for IPv6 routing and DNS
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.6443] device (eth0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jan 30 13:11:54 colibri-imx8x-07329158 kernel: IPv4: martian source 192.168.178.89 from 192.168.178.89, on dev mlan0
Jan 30 13:11:54 colibri-imx8x-07329158 kernel: ll header: 00000000: ff ff ff ff ff ff 00 0e c6 a0 54 e0 08 06
I wasn’t quick enough to get nmcli device status output while only the ethernet connection was working as I only re-read your post later (my bad) and the WLAN connection got reestablished after I plugged in the LAN cable, here’s how it looks with both back up:
DEVICE TYPE STATE CONNECTION
eth0 ethernet connected Wired connection 1
mlan0 wifi connected Escapeverse.de
uap0 wifi disconnected --
ethernet0 ethernet unavailable --
br-9f6e87ccf015 bridge unmanaged --
br-fefdd16d2313 bridge unmanaged --
docker0 bridge unmanaged --
veth01dc154 ethernet unmanaged --
veth5b22356 ethernet unmanaged --
vethdb4636f ethernet unmanaged --
sit0 iptunnel unmanaged --
lo loopback unmanaged --
…and here are all the messages from NetworkManager since boot:
journalctl --unit NetworkManager -n 500 excerpt
Jan 30 13:00:30 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242030.8867] device (mlan0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jan 30 13:00:30 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242030.8880] device (mlan0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jan 30 13:00:30 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242030.8899] manager: NetworkManager state is now CONNECTED_LOCAL
Jan 30 13:00:30 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242030.8933] manager: NetworkManager state is now CONNECTED_SITE
Jan 30 13:00:30 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242030.8946] policy: set 'Escapeverse.de' (mlan0) as default for IPv4 routing and DNS
Jan 30 13:00:30 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242030.8983] device (mlan0): Activation: successful, device activated.
Jan 30 13:00:30 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242030.9017] manager: NetworkManager state is now CONNECTED_GLOBAL
Jan 30 13:00:32 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242032.8210] dhcp6 (mlan0): activation: beginning transaction (timeout in 45 seconds)
Jan 30 13:00:32 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242032.8246] policy: set 'Escapeverse.de' (mlan0) as default for IPv6 routing and DNS
Jan 30 13:00:33 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242033.0259] dhcp6 (mlan0): state changed new lease
Jan 30 13:00:40 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242040.8692] manager: (docker0): new Bridge device (/org/freedesktop/NetworkManager/Devices/6)
Jan 30 13:00:41 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242041.0294] manager: (br-9f6e87ccf015): new Bridge device (/org/freedesktop/NetworkManager/Devices/7)
Jan 30 13:00:41 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242041.1638] manager: (br-fefdd16d2313): new Bridge device (/org/freedesktop/NetworkManager/Devices/8)
Jan 30 13:00:44 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242044.5132] manager: (vethfcdebd7): new Veth device (/org/freedesktop/NetworkManager/Devices/9)
Jan 30 13:00:44 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242044.5663] manager: (veth01dc154): new Veth device (/org/freedesktop/NetworkManager/Devices/10)
Jan 30 13:00:44 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242044.6130] manager: (veth5d33e72): new Veth device (/org/freedesktop/NetworkManager/Devices/11)
Jan 30 13:00:44 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242044.6257] manager: (vethdb4636f): new Veth device (/org/freedesktop/NetworkManager/Devices/12)
Jan 30 13:00:46 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242046.9527] device (vethdb4636f): carrier: link connected
Jan 30 13:00:46 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242046.9542] device (br-fefdd16d2313): carrier: link connected
Jan 30 13:00:46 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242046.9549] device (veth01dc154): carrier: link connected
Jan 30 13:00:46 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242046.9563] device (br-9f6e87ccf015): carrier: link connected
Jan 30 13:02:01 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242121.6841] manager: (veth3b08c10): new Veth device (/org/freedesktop/NetworkManager/Devices/13)
Jan 30 13:02:01 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242121.7084] manager: (veth5b22356): new Veth device (/org/freedesktop/NetworkManager/Devices/14)
Jan 30 13:02:03 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242123.1522] device (veth5b22356): carrier: link connected
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.7492] device (eth0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.7508] device (eth0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.7529] manager: NetworkManager state is now CONNECTED_GLOBAL
Jan 30 13:11:54 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242714.7551] device (eth0): Activation: successful, device activated.
Jan 30 13:14:11 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242851.8705] device (uap0): set-hw-addr: set MAC address to A2:5A:17:E0:1C:B1 (scanning)
Jan 30 13:14:11 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242851.8724] device (uap0): supplicant interface state: inactive -> interface_disabled
Jan 30 13:14:11 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242851.9829] device (uap0): supplicant interface state: interface_disabled -> disconnected
Jan 30 13:14:11 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738242851.9896] device (uap0): supplicant interface state: disconnected -> inactive
Jan 30 13:21:11 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738243271.1284] device (uap0): set-hw-addr: set MAC address to 32:C2:F6:60:4F:9D (scanning)
Jan 30 13:21:11 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738243271.1315] device (uap0): supplicant interface state: inactive -> interface_disabled
Jan 30 13:21:11 colibri-imx8x-07329158 NetworkManager[720]: <info> [1738243271.2483] device (uap0): supplicant interface state: interface_disabled -> inactive
Regarding sleep/suspend modes: not that I know, but how can I check?
