Hi Support,
We’re currently trying to get the LM006 USB wifi module up and running on a Colibri VF61 under WEC 2013.
After installing the drivers and saving the registry, I reboot the board and try and enumerate the WiFi interfaces using the native WiFi demo app, but the interface isn’t detected. The call to WlanEnumInterfaces succeeds, but the retrieved interface list is empty. The WiFi interface also doesn’t show up in the Network Connections control panel. The LM006 being used has been tested on a normal PC and the hardware works just fine.
To the questions:
- Are any other registry changes required to get the adapter working?
- Is there a setting to enable verbose boot messages during WEC 2013 boot, so I can see what hardware is around?
- Is there any other way of verifying that the driver has been loaded and adapter enumerated by the OS?
Any advice is much appreciated, as always.
