Wi-Fi adapter reboots the system
I’m facing a problem while using a Wi-Fi USB adapter: TL-WN722N.
It was working just fine three months ago and suddenly it stopped worked, forcing the system to reboot every 10 seconds. If I try to turn it on without the wi-fi module it works.
I’ve tried to change the module with another that we had, but nothing changed. I’ve even tried to change the Aster and Colibri with others but it remains rebooting.
I’m using this repository: GitHub - lwfinger/rtl8188eu: Repository for stand-alone RTL8188EU driver.
Branch: v5.2.2.4
Colibri iMX6 DualLite 512MB
Aster v1.1
putty msg.txt (4.3 KB)
Hi @cgrodrigo ,
It seems that some issues are occurring in the kernel stack.
What exactly version of software are you using right now? If you are using Torizon OS 5, can you please follow the same steps on Torizon OS 6? They have difference kernel versions and may solve your issue.
Daniel Morais
