Hi, @jaski.
Could you provide the version of the bsp ( uname -a ) of your module?
$ uname -a
Linux Rogers-OptiPlex-3050 4.15.0-39-generic #42-Ubuntu SMP Tue Oct 23 15:48:01 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Did you make any changes to the Software/kernel?
No.
How did you connect the camera module to the Ixora Board?
Through the MIPI-CSI connector (designator X28).
Please share also the complete dmesg log when you start the module with connected camera module?
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.44-2.7.4+gb1555bf (yocto@45574f02061f) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP Wed Oct 4 22:39:51 UTC 2017
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Toradex Apalis iMX6Q/D Module on Ixora V1.1 Carrier Board
[ 0.000000] Reserved memory: created CMA memory pool at 0x3c000000, size 320 MiB
[ 0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 262144
[ 0.000000] free_area_init_node: node 0, pgdat 8095adc0, node_mem_map ab757000
[ 0.000000] Normal zone: 2048 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 262144 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 12 pages/cpu @ab700000 s16588 r8192 d24372 u49152
[ 0.000000] pcpu-alloc: s16588 r8192 d24372 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[ 0.000000] Kernel command line: enable_wait_mode=off vmalloc=400M ip=off root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fec_mac=00:14:2d:4d:45:57 consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 mxc_hdmi.only_cea=1 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 700860K/1048576K available (6751K kernel code, 239K rwdata, 2224K rodata, 332K init, 421K bss, 20036K reserved, 327680K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc0800000 - 0xff000000 (1000 MB)
[ 0.000000] lowmem : 0x80000000 - 0xc0000000 (1024 MB)
[ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
[ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
[ 0.000000] .text : 0x80008000 - 0x808cc0bc (8977 kB)
[ 0.000000] .init : 0x808cd000 - 0x80920000 ( 332 kB)
[ 0.000000] .data : 0x80920000 - 0x8095bf20 ( 240 kB)
[ 0.000000] .bss : 0x8095bf20 - 0x809c56a0 ( 422 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 16 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76470001
[ 0.000000] mxc_clocksource_init 3000000
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000006] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000023] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.001109] Console: colour dummy device 80x30
[ 0.001700] console [tty1] enabled
[ 0.001725] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.001762] pid_max: default: 32768 minimum: 301
[ 0.001866] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001891] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002458] Initializing cgroup subsys freezer
[ 0.002494] Initializing cgroup subsys debug
[ 0.002528] CPU: Testing write buffer coherency: ok
[ 0.002840] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002946] Setting up static identity map for 0x10008280 - 0x100082d8
[ 0.004761] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005388] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006093] Brought up 4 CPUs
[ 0.006168] SMP: Total of 4 processors activated (24.00 BogoMIPS).
[ 0.006188] CPU: All CPU(s) started in SVC mode.
[ 0.006670] devtmpfs: initialized
[ 0.019872] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.020278] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.020333] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.039069] pinctrl core: initialized pinctrl subsystem
[ 0.040241] NET: Registered protocol family 16
[ 0.048343] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.069694] cpuidle: using governor ladder
[ 0.099689] cpuidle: using governor menu
[ 0.099970] CPU identified as i.MX6Q, silicon rev 1.5
[ 0.124644] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.124688] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.125682] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.127242] imx-gpc 20dc000.gpc: no fsl,ldo-bypass found!
[ 0.136635] usb_host_vbus: supplied by usb_host_vbus_hub
[ 0.136966] vgaarb: loaded
[ 0.137729] SCSI subsystem initialized
[ 0.137929] libata version 3.00 loaded.
[ 0.138235] usbcore: registered new interface driver usbfs
[ 0.138324] usbcore: registered new interface driver hub
[ 0.138426] usbcore: registered new device driver usb
[ 0.139108] i2c-gpio i2c@0: using pins 80 (SDA) and 62 (SCL)
[ 0.140013] i2c i2c-1: IMX I2C adapter registered
[ 0.140047] i2c i2c-1: can't use DMA
[ 0.141577] stmpe-i2c 2-0041: stmpe811 detected, chip id: 0x811
[ 0.143484] i2c i2c-2: IMX I2C adapter registered
[ 0.143518] i2c i2c-2: can't use DMA
[ 0.144232] i2c i2c-3: IMX I2C adapter registered
[ 0.144267] i2c i2c-3: can't use DMA
[ 0.144425] Linux video capture interface: v2.00
[ 0.144498] pps_core: LinuxPPS API ver. 1 registered
[ 0.144520] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.144572] PTP clock support registered
[ 0.159739] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.179734] imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.180644] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed ipu0 csi1
[ 0.180689] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
[ 0.180797] MIPI CSI2 driver module loaded
[ 0.180998] Advanced Linux Sound Architecture Driver Initialized.
[ 0.182661] Switched to clocksource mxc_timer1
[ 0.193498] NET: Registered protocol family 2
[ 0.194263] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.194365] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.194501] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.194590] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.194644] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.194862] NET: Registered protocol family 1
[ 0.195172] RPC: Registered named UNIX socket transport module.
[ 0.195199] RPC: Registered udp transport module.
[ 0.195217] RPC: Registered tcp transport module.
[ 0.195236] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.195269] PCI: CLS 0 bytes, default 64
[ 0.195952] CPU PMU: Failed to parse /soc/pmu/interrupt-affinity[0]
[ 0.196021] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.197715] Bus freq driver module loaded
[ 0.204802] VFS: Disk quotas dquot_6.6.0
[ 0.205009] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.206571] NFS: Registering the id_resolver key type
[ 0.206624] Key type id_resolver registered
[ 0.206645] Key type id_legacy registered
[ 0.206683] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.207210] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.207686] fuse init (API version 7.23)
[ 0.211695] io scheduler noop registered
[ 0.211737] io scheduler deadline registered
[ 0.211918] io scheduler cfq registered (default)
[ 0.214247] backlight supply power not found, using dummy regulator
[ 0.215842] MIPI DSI driver module loaded
[ 0.217237] 20e0000.hdmi_video supply HDMI not found, using dummy regulator
[ 0.218746] mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
[ 0.218805] fbcvt: 1920x1080@60: CVT Name - 2.073M9
[ 0.218932] mxc_sdc_fb fb@0: registered mxc display driver hdmi
[ 0.234020] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 0.252747] imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
[ 0.286624] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 0.324254] Console: switching to colour frame buffer device 240x67
[ 0.359419] mxc_sdc_fb fb@1: mxcfb1 is turned off!
[ 0.359575] mxc_sdc_fb fb@2: mxcfb2 is turned off!
[ 0.359720] mxc_sdc_fb fb@3: mxcfb3 is turned off!
[ 0.361170] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[ 0.361608] imx-sdma 20ec000.sdma: no event needs to be remapped
[ 0.361941] imx-sdma 20ec000.sdma: loaded firmware 3.3
[ 0.364639] imx-sdma 20ec000.sdma: initialized
[ 0.366373] pfuze100-regulator 2-0008: Full layer: 2, Metal layer: 1
[ 0.367092] pfuze100-regulator 2-0008: FAB: 0, FIN: 0
[ 0.367191] pfuze100-regulator 2-0008: pfuze100 found.
[ 0.381965] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 26, base_baud = 5000000) is a IMX
[ 1.250950] console [ttymxc0] enabled
[ 1.255582] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 301, base_baud = 5000000) is a IMX
[ 1.264995] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 302, base_baud = 5000000) is a IMX
[ 1.274377] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 303, base_baud = 5000000) is a IMX
[ 1.284069] [drm] Initialized drm 1.1.0 20060810
[ 1.289167] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[ 1.303367] brd: module loaded
[ 1.311558] loop: module loaded
[ 1.315939] ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
[ 1.324038] ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
[ 1.332188] ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
[ 1.340528] ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
[ 1.351713] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
[ 1.358864] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 1.367827] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 1.378440] scsi host0: ahci-imx
[ 1.382053] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 313
[ 1.392179] spi_imx 2008000.ecspi: probed
[ 1.397176] vcan: Virtual CAN interface driver
[ 1.401718] CAN device driver interface
[ 1.410648] 2090000.flexcan supply xceiver not found, using dummy regulator
[ 1.423387] flexcan 2090000.flexcan: device registered (reg_base=c0a98000, irq=35)
[ 1.436102] 2094000.flexcan supply xceiver not found, using dummy regulator
[ 1.448809] flexcan 2094000.flexcan: device registered (reg_base=c0aa0000, irq=36)
[ 1.462527] 2188000.ethernet supply phy not found, using dummy regulator
[ 1.493064] pps pps0: new PPS source ptp0
[ 1.503413] libphy: fec_enet_mii_bus: probed
[ 1.514450] fec 2188000.ethernet eth0: registered PHC device 0
[ 1.525691] usbcore: registered new interface driver asix
[ 1.536209] usbcore: registered new interface driver ax88179_178a
[ 1.547369] usbcore: registered new interface driver cdc_ether
[ 1.558277] usbcore: registered new interface driver net1080
[ 1.568940] usbcore: registered new interface driver cdc_subset
[ 1.579808] usbcore: registered new interface driver zaurus
[ 1.590340] usbcore: registered new interface driver cdc_ncm
[ 1.600837] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.612257] ehci-pci: EHCI PCI platform driver
[ 1.621668] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.632079] usbcore: registered new interface driver usb-storage
[ 1.643143] usbcore: registered new interface driver usbserial
[ 1.653897] usbcore: registered new interface driver usbserial_generic
[ 1.665235] usbserial: USB Serial support registered for generic
[ 1.676040] usbcore: registered new interface driver ftdi_sio
[ 1.686568] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.698698] usbcore: registered new interface driver pl2303
[ 1.709073] usbserial: USB Serial support registered for pl2303
[ 1.720980] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.732701] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.732742] ahci-imx 2200000.sata: no device found, disabling link.
[ 1.732749] ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
[ 1.777502] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 1.787037] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 1.812699] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 1.823666] hub 1-0:1.0: USB hub found
[ 1.832117] hub 1-0:1.0: 1 port detected
[ 1.841743] mousedev: PS/2 mouse device common for all mice
[ 1.860880] input: stmpe-ts as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-2/2-0041/stmpe-ts/input/input0
[ 1.879593] rtc-ds1307 1-0068: rtc core: registered m41t0 as rtc0
[ 1.891198] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[ 1.905026] i2c /dev entries driver
[ 1.914838] mxc_v4l2_output v4l2_out: V4L2 device registered as video16
[ 1.926645] mxc_v4l2_output v4l2_out: V4L2 device registered as video17
[ 1.939601] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.950661] sdhci: Secure Digital Host Controller Interface driver
[ 1.961777] sdhci: Copyright(c) Pierre Ossman
[ 1.971092] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.982587] /soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
[ 1.994761] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 2.006266] sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
[ 2.062814] mmc1: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 2.075674] /soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
[ 2.088265] sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
[ 2.142691] mmc0: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[ 2.160312] mxc_vpu 2040000.vpu_fsl: VPU initialized
[ 2.170428] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 2.182501] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[ 2.198004] caam 2100000.caam: Entropy delay = 3200
[ 2.226965] mmc0: MAN_BKOPS_EN bit is not set
[ 2.255774] mmc0: new DDR MMC card at address 0001
[ 2.265959] mmcblk0: mmc0:0001 004GE0 3.69 GiB
[ 2.268783] caam 2100000.caam: Instantiated RNG4 SH0
[ 2.285589] mmcblk0boot0: mmc0:0001 004GE0 partition 1 2.00 MiB
[ 2.296650] mmcblk0boot1: mmc0:0001 004GE0 partition 2 2.00 MiB
[ 2.321177] mmcblk0: p1 p2
[ 2.329545] caam 2100000.caam: Instantiated RNG4 SH1
[ 2.339386] caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
[ 2.350932] caam 2100000.caam: job rings = 2, qi = 0
[ 2.438320] caam algorithms registered in /proc/crypto
[ 2.443868] hub 1-1:1.0: USB hub found
[ 2.443944] hub 1-1:1.0: 4 ports detected
[ 2.469641] caam_jr 2101000.jr0: registering rng-caam
[ 2.480283] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[ 2.491100] snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
[ 2.504160] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.514695] usbcore: registered new interface driver usbhid
[ 2.525265] usbhid: USB HID core driver
[ 2.539510] stmpe-adc stmpe-adc: Initialized
[ 2.551121] sgtl5000 2-000a: sgtl5000 revision 0x11
[ 2.722315] imx-sgtl5000 sound: sgtl5000 <-> 2028000.ssi mapping ok
[ 2.736034] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
[ 2.751442] imx-audio-hdmi sound-hdmi: hdmi-hifi <-> soc:hdmi_audio@00120000 mapping ok
[ 2.766029] NET: Registered protocol family 10
[ 2.776630] NET: Registered protocol family 17
[ 2.786267] can: controller area network core (rev 20120528 abi 9)
[ 2.797667] NET: Registered protocol family 29
[ 2.807252] can: raw protocol (rev 20120528)
[ 2.816599] can: broadcast manager protocol (rev 20120528 t)
[ 2.827348] can: netlink gateway (rev 20130117) max_hops=1
[ 2.838357] Key type dns_resolver registered
[ 2.849438] Registering SWP/SWPB emulation handler
[ 2.860257] 1ffc000.pcie supply pcie-bus not found, using dummy regulator
[ 3.278508] imx6q-pcie 1ffc000.pcie: phy link never came up
[ 3.288142] imx6q-pcie 1ffc000.pcie: failed to initialize host
[ 3.298096] imx6q-pcie: probe of 1ffc000.pcie failed with error -22
[ 3.310660] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 3.322649] rtc-ds1307 1-0068: setting system clock to 2018-12-12 14:29:46 UTC (1544624986)
[ 3.343118] usb_otg_vbus: disabling
[ 3.350913] ALSA device list:
[ 3.357901] #0: imx6q-apalis-sgtl5000
[ 3.365659] #1: imx-spdif
[ 3.372280] #2: imx-hdmi-soc
[ 3.392219] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.404411] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.418484] devtmpfs: mounted
[ 3.425698] Freeing unused kernel memory: 332K
[ 3.526869] random: systemd urandom read with 14 bits of entropy available
[ 3.541520] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ +LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD +IDN)
[ 3.564208] systemd[1]: Detected architecture arm.
[ 3.593491] systemd[1]: Set hostname to <apalis-imx6>.
[ 3.772268] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.802832] systemd[1]: Reached target Remote File Systems.
[ 3.832986] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.863125] systemd[1]: Created slice System Slice.
[ 3.893070] systemd[1]: Created slice system-getty.slice.
[ 3.923444] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.973211] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.013491] systemd[1]: Listening on Network Service Netlink Socket.
[ 4.053004] systemd[1]: Reached target Swap.
[ 4.083083] systemd[1]: Listening on udev Kernel Socket.
[ 4.113199] systemd[1]: Listening on udev Control Socket.
[ 4.143416] systemd[1]: Created slice User and Session Slice.
[ 4.172990] systemd[1]: Reached target Slices.
[ 4.203310] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.242962] systemd[1]: Reached target Paths.
[ 4.292006] systemd[1]: Listening on Journal Socket.
[ 4.330039] systemd[1]: Starting Load Kernel Modules...
[ 4.363015] Galcore version 5.0.11.41671
[ 4.365021] systemd[1]: Mounting Debug File System...
[ 4.406908] systemd[1]: Mounting Temporary Directory...
[ 4.446738] systemd[1]: Starting Export GPIOs to user space...
[ 4.487009] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 4.517376] systemd[1]: Starting Journal Service...
[ 4.557507] systemd[1]: Starting Setup Virtual Console...
[ 4.596613] systemd[1]: Starting File System Check on Root Device...
[ 4.637097] systemd[1]: Mounted Debug File System.
[ 4.649380] systemd[1]: Mounted Temporary Directory.
[ 4.663595] systemd[1]: Started Journal Service.
[ 4.747225] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.982579] systemd-journald[194]: Received request to flush runtime journal from PID 1
[ 5.444557] adv7280 3-0021: chip found @ 0x42 (21a8000.i2c)
[ 5.456336] adv7280 3-0021: no sensor pwdn pin available
[ 5.483313] adv7280 3-0021: adv7280_probe:Analog Device adv7280 not detected -5!
[ 5.520915] max9526 3-0020: Device seems not to be a MAX9526
[ 5.544536] /soc/aips-bus@02100000/i2c@021a8000/ov5640_mipi@3c: arguments longer than property
[ 5.883727] mxc_v4l2_master_attach: ipu0:/csi1 parallel attached ov564x_mipi:mxc_v4l2_cap1
[ 5.896689] camera ov5640_mipi is found
[ 6.018031] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 6.161978] using random self ethernet address
[ 6.171267] using random host ethernet address
[ 6.179342] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.410271] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 6.421313] usb0: MAC 00:14:2d:ff:ff:ff
[ 6.533749] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.653591] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=2188000.ethernet:07, irq=69)
[ 6.671804] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.718629] ov5640_set_virtual_channel: virtual channel=1
[ 7.031093] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 7.081593] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 7.126605] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 7.177012] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 7.556012] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 8.272495] random: nonblocking pool is initialized
[ 10.166338] fec 2188000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 10.174147] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.439290] ci_hdrc ci_hdrc.0: Device No Response
[ 204.145512] ov5640_set_virtual_channel: virtual channel=1
[ 204.502018] YUV420
[ 8532.535891] ov5640_set_virtual_channel: virtual channel=1
[ 8532.899700] YUV420
