I am building the tdx-reference-minimal-image using the toradex-manifest git repository.
I have extra layers I include for my custom application and systemd services.
When running my built image I am seeing the boot partition get mounted twice.
I also see my other generated partitions being auto mounted.
root@streamProcessor:~# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk2 179:0 0 29.1G 0 disk
|-mmcblk2p1 179:1 0 48M 0 part /boot
| /media/BOOT-mmcblk2p1
|-mmcblk2p2 179:2 0 10.4G 0 part /
What can I do to stop these from being auto mounted?
I am assuming it is something to do with udev? As I am pretty sure we add something for that so we can disable the mounting of USB storage devices for security reasons.
My custom partitions I assume I can just add to the mount.ignorelist
file, but I am not sure that is possible for the boot partition as I think that would cause none of the mounts to occur.
I suspect it is an ordering thing between the automount.rules
from udev-extraconf
and the bootpart-automount.rules
which appears to be a toradex thing (as it points to a toradex names script file).
The issue you’re encountering with the boot partition being mounted twice seems to be related to the automount features provided by udev
rules, as you’ve correctly identified. This can happen when multiple rules are set to mount partitions upon detection, which is common in systems designed to be user-friendly by automatically mounting filesystems for easy access.
To address this issue, you can take the following steps:
Review and Modify Udev Rules: Start by reviewing the udev
rules related to automounting. Look for files like automount.rules
and bootpart-automount.rules
within /etc/udev/rules.d/
or /lib/udev/rules.d/
. You might find rules that automatically mount partitions based on their labels or types. If the boot partition is being mounted by both a generic automount rule and a Toradex-specific rule, you may need to adjust these rules to prevent double mounting.
Customize Mount Options: For your custom partitions, adding entries to the mount.ignorelist
is a good approach. However, for the boot partition, since it needs to be mounted for the system to function correctly, you cannot simply ignore it. Instead, you might need to customize the rule that mounts the boot partition to ensure it’s only mounted once, in the desired location.
Ordering of Udev Rules: Udev processes rules in lexical order, so the order in which rules are applied matters. You can rename the rule files to change the order in which they are processed. Files are processed in lexical order, so prefixing filenames with numbers can control the order (e.g., 10-automount.rules
would be processed before 90-bootpart-automount.rules
). Adjusting the order might help resolve conflicts between rules.
Disable Unnecessary Rules: If certain automount features are not required for your application, you can disable them by renaming the rule files to have a .disabled
extension or by commenting out specific lines in the rule files. This can help prevent unwanted automount behavior.
Udev Control: If the automounting is indeed being triggered by udev
, and if it’s not critical for your use case, consider disabling the specific udev
rule responsible for the unwanted mount. This might involve commenting out or modifying the rule that matches your boot partition.
Systemd Mount Units: Check if there are any systemd mount units (*.mount
) responsible for mounting these partitions. Systemd might be
Distro Boot | Toradex Developer Center.
Hello @izzy_building,
That is correct, you can also use this for /dev/mmcblk2p1
This will result in the boot partition not being mounted when the system is up, but this does not stop the system for booting or loading the device tree or overlays.
If you just want /boot
to not be mounted, while keeping /media/BOOT-mmcblk2p1
, you can remove the /etc/udev/scripts/toradex-mount-bootpart.sh
script from your image, as it is responsible for this extra mount point.
This file is added by the udev-toradex-rules recipe.
Bruno
@bruno.tx
So I could also remove the bootpart-automount.rules
file too? this is what creates the rule to call that script.
I assume this is then not responsible for mounting it as /boot
I apologize for the confusion, my previous comment was incorrect.
The /etc/udev/scripts/toradex-mount-bootpart.sh
script is actually used to create the /boot
mountpoint.
The /media/BOOT-mmcblk2p1
mountpoint is the one created by default.
I will correct my previous comment to reflect that.
Yes, if you don’t need the /etc/udev/scripts/toradex-mount-bootpart.sh
script, you can remove the bootpart-automount.rules
file.
Bruno
@bruno.tx
So just to confirm…
If I want to remove the /boot
mount I remove the toradex script and bootpart-automount.rules
in udev-toradex-rules.bbappend
But if I want to remove the /media/...
ones then I can add /dev/mmcblk2p[0-9]*
in udev-extraconf_%.bbappend
I believe that is what you are saying?
That is correct.
By adding /dev/mmcblk2p[0-9]*
file, you end up without /media/...
and /boot
, as the /media/...
mount is the default one.
A possible approach to keep only the /boot
mount, could be to modify the toradex-mount-bootpart.sh
script to unmount the /media/...
mount after /boot
is mounted.
Bruno
