This should be simple, but the data sheets for both the Dahlia and full sized Verdin carrier boards are useless tracking this down.
There is a “Mini PCIe” disk drive connector on the carrier boards. Nowhere does it say what standard the firmware supports out of the box. There’s an M.2 228 standard. M.2 2230 standard, M.3 standard
So, what, on this NewEgg page
can be plugged in and your standard Torizon load from the EasyInstaller will recognize so it can be partitioned and formatted?
I suspect it supports this one.
Only because that is in a lot of notebooks.
The Gen 3 has a smaller tab edge.
Would hate to think you opted for the Dell drive because those are massively overpriced.
All of the M.2 2280s aren’t the same connector wise.
What can be bought off the shelf and will “just work?” It had to have gotten tested with something.
Thanks,
Roland
