I’m building kernel for Colibri iMX6ULL 512MB Wi-Fi / Bluetooth which has WM828CC6 wifi/bt module. I couldn’t find any driver related to WM828CC6 in kernel. Can anyone please help me to enable driver for WM828CC6 in kernel?
I have enabled following drivers in Kernel for Wifi and BT
- Marvell WiFi-Ex Driver Marvell
- WiFi-Ex Driver for SD8786/SD8787/SD8797/SD8887/SD8897/SD8997
- Marvell Bluetooth driver support
- Marvell BT-over-SDIO driver
You can see following drivers loaded after enabling above drivers.
btmrvl_sdio 15979 0 - Live 0x7f12c000
mwifiex_sdio 27632 0 - Live 0x7f120000
btmrvl 12942 1 btmrvl_sdio, Live 0x7f118000
mwifiex 269459 1 mwifiex_sdio, Live 0x7f0c6000
bluetooth 338572 3 btmrvl_sdio,btmrvl, Live 0x7f060000
cfg80211 254681 1 mwifiex, Live 0x7f00f000
Note: You also need sd8887_uapsta.bin firmware for getting mlan0 interface. Copy it to /lib/firmware/mrvl/sd8887_uapsta.bin
Perfect that you solved the issue yourself. Thanks for the feedback.
