I’m reading up on the Yocto Project, and the use of Open Embedded Core on the Apalis platform. I will likely build an image from source at some point in the future, but would like to get the device up and running with a pre-built image from Toradex.
One clarification I have after reading the Toradex guidelines. My device will be using EGLFS, so won’t need a desktop environment, such as LXDE. The BSP image download directory specifies ‘LXDE-Image’ or ‘LinuxImage’ as the options for Apalis iMX6. The guideline suggests there should also be a console-image option; as this option is not currently shown in the download directory, which version should I be using for EGLFS on Apalis iMX6?
Thanks!
