If I import the module pprint in a python script then I get the error:
ImportError: No module named pprint
What am I doing wrong? I use the image Colibri_VF_LinuxImageV2.5_20151215.tar.bz2 from Toradex.
python-pprint package is installed ?
May i know how exactly are you installing python ?
I installed it with the package manager, using
opkg update
opkg install python
The current Python Version is 2.7.9-r1.2
That’s the solution. Thank you for the quick support!
python-pprint package would also require installation with
opkg install python-pprint
Check for the available python packages here.
Note that V2.5 is using the packages from the Ångström distribution v2015.06:
Hi JessicaW
Do you have a specific issue/question related to toradex modules? If yes, then ask a new question please!
