I’m eagerly testing the upcoming (morty-based) release of the Toradex BSP. For this I’m trying to build the angstrom-lxde-image. It’s pulling in the package imx-gst1.0-plugin-4.1.4 but the link to the nxp-website referencing a required archive is down and any mirrors fail as well:
ERROR: imx-gst1.0-plugin-4.1.4-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-hMrA4kjEfO,guid=98417145bdb7bb7e7083c5b0584a561e"; export SSH_AGENT_PID="1236"; export SSH_AUTH_SOCK="/tmp/ssh-Sf8hYRIx18oo/agent.1185"; export PATH="/home/ipek/yocto/toradex/layers/openembedded-core/scripts:/home/ipek/yocto/toradex/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi:/home/ipek/yocto/toradex/build/tmp-glibc/sysroots/apalis-imx6/usr/bin/crossscripts:/home/ipek/yocto/toradex/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/ipek/yocto/toradex/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/ipek/yocto/toradex/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/ipek/yocto/toradex/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/ipek/yocto/toradex/layers/openembedded-core/scripts:/home/ipek/yocto/toradex/layers/openembedded-core/bitbake/bin:/home/ipek/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"; export HOME="/home/ipek"; /usr/bin/env wget -t 2 -T 30 -nv --passive-ftp --no-check-certificate -P /home/ipek/yocto/toradex/build/downloads 'http://www.freescale.com/lgfiles/NMG/MAD/YOCTO//imx-gst1.0-plugin-4.1.4.tar.gz' --progress=dot -v failed with exit code 8, output:
--2016-12-09 10:56:12-- http://www.freescale.com/lgfiles/NMG/MAD/YOCTO//imx-gst1.0-plugin-4.1.4.tar.gz
Resolving www.freescale.com (www.freescale.com)... 95.101.66.67
Connecting to www.freescale.com (www.freescale.com)|95.101.66.67|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-gst1.0-plugin-4.1.4.tar.gz [following]
--2016-12-09 10:56:13-- http://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-gst1.0-plugin-4.1.4.tar.gz
Resolving www.nxp.com (www.nxp.com)... 23.42.16.48
Connecting to www.nxp.com (www.nxp.com)|23.42.16.48|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2016-12-09 10:56:13 ERROR 404: Not Found.
This package seems to be somewhat unobtainable
has it been revoked? There are several commits in the meta-freescale branch referencing it, so I assume it used to be available short ago.
The pre-built image of Toradex BSP LinuxImageV2.6.2 contain only the gst-fsl-plugin, which is afaik no longer available in the morty meta-freescale layer.
Do you have an offline copy of the archive imx-gst1.0-plugin-4.1.4.tar.gz which you can provide?
Kind regards
Christian
