We’re using a custom hardware based on the Colibri iMX6S Module with an Analogue Camera Adapter using ADV7180.
We came across some problems that we were able to overcome with the support of this community:
- Firmware upgrade with Toradex Easy Installer using only the RNDIS interface
- Analog camera selection with adv7180
This was because our final board only provides USB connectivity and has 3 analog camera inputs.
I checked the ADI kernel driver for adv7180 located in “drivers/media/i2c/adv7180.c”, and it appears to implement the interfaces for the v4l2 subsystem with more completeness than the mxc driver located in “drivers/media/platform/mxc/capture/adv7180.c”, that relies on the v4l2 interfaces defined in the file “v4l2-int-device.h” that has been removed from the kernel (include/media/v4l2-int-device.h) prior to the version 4.0
I’m still getting acquainted with the v4l2 subsystem, but I see that in the mxc case, a v4l2 device is implemented by multiple device drivers, where the main driver mxc_v4l2_capture controls the driver for the adv7180, which provides some ioctl-like interfaces to be called by mxc_v4l2_capture.
I would like to understand what would be the reasons for this, and how much porting work would be required to use the ADI driver. We need a more complete control of the ADV7180.
