I want to develop on Windows Embedded Compact and I see that different versions of Visual Studio are available.
Which one should I use?
The version of Visual Studio you should use depends of the version of Windows Embedded Compact you plan to run on your modules.
If you plan to run Windows CE 6 or Windows Embedded Compact 7 then you need to use Visual Studio 2008, if you plan to run Windows Embedded Compact 2013 then you can use Visual Studio 2013 or Visual Studio 2015.
For Visual Studio 2008 you need, at least, the Professional version of Visual Studio. Development for embedded devices is not supported in the express version.
You may use the Community edition of Visual Studio 2013, but this version (that is feature-comparable with the Professional one) has some licensing limitation about the scope of your project and the size of your company and development team.
You can have them installed side by side on your development machine, the only thing you need to do is to setup VS2008 first and then VS2013/VS2015.
We provide SDKs that you can install to develop your application targeting our modules:
Toradex Embedded Software Documentation Overview | Toradex Developer Center
If you need to develop applications you need just the SDK (for Visual Studio 2008) or the SDK and Application Builder (for Visual Studio 2013/2015) available here:
http://www.microsoft.com/en-us/download/details.aspx?id=38819
If you need to build a Windows Embedded Compact OS image using our BSP you need to install also Platform Builder. Platform Builder is OS-version specific and you need:
- VS2005 for Windows CE6
- VS2008 for Windows Embedded Compact 7
- VS2013/VS2015 for Windows Embedded Compact 2013
On CE6 and Windows Embedded Compact 7 Platfom Builder requires a license but it includes also the license for Visual Studio.
The installation of Application Builder for Windows Compact Embedded 2013 keeps failing as it requests Visual Studio Professional or Enterpreside 2015 (license required).
It does not seem to accept VS 2013 Community which is what we need to evaluate the OS and boards for our target development.
Could you confirm that as of August 2016 it is still possible to install App Builder for Windows CE 2013 having previously installed VS 2013 Community Ed only?
Unfortunately, since VS2015 support was added to platform builder it seems that the community version is not longer supported. You may download an evaluation version of VS2015 from Microsoft’s website, this should be time-limited but functional.
i really like this so many logos watched but you have some different kind
Hello ,Can you please specify the Support of WIN CE 2013 For T20 Colibri Module I want to use Graphical interface using C#.
@t20 please create a new question for your request as per our community rules, thanks:
https://www.toradex.com/community/page/howto.html
What about 2017? Visual Studio 2017 호환성 VS | Microsoft Learn
Currently there are no announcements from Microsoft about support for Windows Embedded Compact 2013 development on Visual Studio 2017.
Hi, thank you for the information. I have VS 2015 CE (Community Edition) installed and when trying to install VSEmbedded AppBuilder (V24930) the installer says, I need at least the professional edition?! Will I need to develop with VS 2013 CE or is there a workaround for installing? thank you! Tilli
Unfortunately the AppBuilder plugin worked with the community edition of VS2013 but is not longer supported on community edition of VS2015.
You’ll have to get the professional version or to use VS2013 if you prefer a free development tool.
Visual Studio 2017 contains many new and exciting features and IDE productivity enhancements to support Windows app development, cross-platform mobile development, Azure development, web and cloud development, and more. To try out Visual Studio 2017, see Visual Studio 2017 Downloads. For more information about everything that’s new in this release, see the Visual Studio 2017 release notes and What’s New in Visual Studio 2017.
For Visual Studio Code, see Visual Studio Code FAQ. For Visual Studio 2017 for Mac, see Visual Studio 2017 for Mac Platform Targeting and Compatibility and Visual Studio 2017 for Mac release notes.
Installation
You can install and use Visual Studio 2017 alongside previous versions of Visual Studio, including Visual Studio 2015, Visual Studio 2013, and Visual Studio 2012.
Download
Click the button to download the latest version of Visual Studio 2017. For instructions, see Install Visual Studio 2017.
Note: Installation package size will vary depending on your current Visual Studio configuration.
System Requirements
For information on the system requirements for installing and running the Visual Studio 2017 family of products, including Team Foundation Server 2017, see the Visual Studio 2017 System Requirement page and Visual Studio 2017 for Mac Product Family System Requirements.
Feedback and Support
For support, or to submit feedback on Visual Studio, see:
- Visual Studio Support
- Submit a product suggestion or idea
- Report a problem or bug
Upgrade Projects to Visual Studio 2017
When following the supported upgrade paths, your Visual Studio source, solutions, and project files will continue to work; however, you should expect to make some changes to sources. While we cannot guarantee binary compatibility between releases, we will do our best to document significant changes to assist you with updates.
For details on how to migrate your projects to Visual Studio 2017, see Porting, Migrating, and Upgrading Visual Studio Projects.
Platform Targeting
Visual Studio provides cutting-edge tools and technologies to create apps that take advantage of the latest platform capabilities, whether Windows, Android, iOS, or Linux. Visual Studio 2017 also targets earlier platforms so you can create new apps or modernize existing apps that execute on earlier versions of Windows while leveraging the enhanced development tools, quality enablement, and team collaboration capabilities in Visual Studio 2017. For more information, see Managing references in a project and Visual Studio Multi-Targeting Overview.
- Developing apps for Windows
- Developing apps for Android
- Developing apps for iOS
- Developing apps for Linux
- Developing apps for macOS
- Developing apps for other technologies and platforms
Please notice that neither Visual Studio 2017 nor Visual Studio Code support Windows Embedded Compact.
