I am trying to set a GPIO to Pullup State . But unablr to do so from the TERA TERM software.
I would like to change PIN 97 & 101 to Pull UP.
I have tried set gpio command in the Boot Command Prompt Window , and this is the output I get.
gpio.gpdr0: 0x0 (GPIO Direction ( 31: 0) 0=In 1=Out)
gpio.gpdr1: 0x0 (GPIO Direction ( 63:32) 0=In 1=Out)
gpio.gpdr2: 0x0 (GPIO Direction ( 95:64) 0=In 1=Out)
gpio.gpdr3: 0x0 (GPIO Direction (120:96) 0=In 1=Out)
gpio.gplr0: 0x0 (GPIO Level ( 31: 0))
gpio.gplr1: 0x0 (GPIO Level ( 63:32))
gpio.gplr2: 0x0 (GPIO Level ( 95:64))
gpio.gplr3: 0x0 (GPIO Level (120:96))
gpio.mfppull_0: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_1: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_3: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_4: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_5: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_6: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_7: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_8: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_9: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_10: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_11: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_12: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_13: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_14: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_15: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_16: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_17: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_18: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_19: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_20: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_21: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_22: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_23: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_24: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_25: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_26: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_27: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_28: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_29: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_30: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_31: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_32: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_33: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_34: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_35: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_36: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_37: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_38: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_39: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_40: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_41: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_42: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_43: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_44: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_45: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_46: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_47: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_48: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_49: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_50: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_51: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_52: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_53: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_54: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_55: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_56: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_57: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_58: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_59: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_60: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_61: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_62: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_63: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_64: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_65: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_66: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_67: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_68: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_69: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_70: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_71: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_72: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_73: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_74: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_75: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_76: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_77: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_78: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_79: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_80: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_81: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_82: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_83: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_84: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_85: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_86: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_87: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_88: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_89: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_90: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_91: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_92: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_93: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_94: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_95: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_96: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_97: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_98: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_99: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_100: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_101: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_102: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_103: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_104: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_105: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_106: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_107: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_108: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_109: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_110: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_111: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_112: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_113: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_114: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_115: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_116: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_117: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_118: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_119: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_120: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_121: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_122: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_123: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_124: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_125: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_126: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_127: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_0_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_1_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_2_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_3_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_4_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_5_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_6_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_7_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_8_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_9_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_10_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_11_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_12_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_13_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_14_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_15_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_16_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
gpio.mfppull_17_2: 0 (0:Float, 1:PullD, 2:PullU, 3:ResetVal)
