Weston multiple displays
I am working on an Verdin IMX8MP. We have two displays connected one is LVDS 1024x768 the other one is a DSI panel (panel_ilitek_ili9881c) 720x1280. I managed to get both display working, using the container torizon/weston-imx8:4.13. My problem is that it seems not possible the get the LVDS display to be the main display (coordinates 0,0 - 1023,767). There must be a possibility to arrange the displays somehow.
I have another problem with Xwayland it is working basically. But in kiosk mode X-winows get an offset of 32 pixels in x and y direction.
I’d be glad to help! Could you let me know which version of Torizon OS you are running? You can check this by running the tdx-info command on your device. This information will help me provide you with the most accurate guidance for your multi-display setup and Xwayland configuration.
You can find more details about the tdx-info command here: Getting Device Information with Tdx-Info | Toradex Developer Center
Dear @andreasr,
Thank you for contacting us and welcome to the community!
Regarding the first issue you mentioned, you should be able to configure this in a file called weston.ini.
I have an example of this here:
[core]
#gbm-format=argb8888
idle-time=0
#use-g2d=1
xwayland=true
repaint-window=16
#enable-overlay-view=1
modules=screen-share.so
shell=kiosk-shell.so
[shell]
panel-position=top
locking=false
allow-zap=true
num-workspaces=1
[libinput]
enable_tap=true
touchscreen_calibrator=true
calibration_helper=/usr/bin/toradex-save-touchscreen-calibration
[output]
name=HDMI-A-1
mode=preffered
transform=normal
app-ids=org.freedesktop.weston.wayland-drag-and-drop-demo
[output]
name=HDMI-A-2
mode=preffered
transform=normal
app-ids=org.freedesktop.weston.flower
[screen-share]
command=/usr/bin/weston --backend=rdp-backend.so --shell=fullscreen-shell.so --no-clients-resize --rdp-tls-cert=/etc/freerdp/keys/server.crt --rdp-tls-key=/etc/freerdp/keys/server.key
In this case two HDMI displays are connected. You should be able to configure your own setup here though. The same goes for the app-ids. Should you want to use different app-ids you can run the following command to fetch the IDs:
bash-5.2# WAYLAND_DEBUG=1 weston-dnd 2>&1 | grep app
[  84796.980]  -> xdg_toplevel@18.set_app_id("org.freedesktop.weston.wayland-drag-and-drop-demo")
bash-5.2# WAYLAND_DEBUG=1 weston-flower 2>&1 | grep app
[2368152.597]  -> xdg_toplevel@17.set_app_id("org.freedesktop.weston.flower")
You can then run the apps via the following example command:
# weston-flower & weston-dnd &
I will check out the other issue regarding the 32 pixel offset in the meantime.
Collin
Thank you. This seems to work. At least for wayland applications. But what do I do with x11 applications?
Dear @andreasr,
Thank you for your feedback.
Newer versions of weston would support the x11-wm-name/x11-wm-class feature, however our weston seems to be too old for that. You would require at least 13.0.91. You might be able to “raise” the weston version via a bbappend. Have you tried this?
Regarding the offset you are witnessing there could be a few reasons for this. Could you send us an image of what you are seeing? The issue could be caused by either weston or from the display settings.
Collin
