Weston-keyboard not working
Hi @arj_don,
Thanks for posting to Toradex community.
If I understand your question, you wanted to use virtual keyboard.
There are couple of option like using weston-keyboard or using keyboard from UI framework like qt.
Here we will share how to get first option
To enable weston-keybord, one will need to modify weston.ini file and add weston-keyboard path under input section.
Please check below similar post for same
Virtual keyboard in Weston? - #2 by gustavo.tx
Ritesh Kumar
