I have developed an application that uses 2 docker containers:
demoui: An electron application
weston: The weston interface manager
Running on a Toradex Development Board, all works fine when using a Verdin iMX8MP board (The iMX8 Plus, that has an HMDI interface)
But when I use a Verdin iMX8MM board (without the HDMI interface), there is no signal on screen, and I´m getting the following errors on Weston container:
Docker running:
$ docker ps
c7874629d043 renatom/demoui:latest "./demoui --no-sand…" 2 hours ago Restarting (133) 27 seconds ago torizon-demoui-1
05fabd4ccf0e commontorizon/weston-imx8:3.3.2 "/usr/bin/entry.sh" 2 hours ago Restarting (1) 51 seconds ago torizon-weston-1
$ docker logs 05fabd4ccf0e
Switching VT tty1 to text mode if currently in graphics mode
Switching VT mode of /dev/tty1 to text
Switching to VT 7
SoC is: 'i.MX8MM'
SoC has GPU: true
SoC has DPU: false
g2d implementation: viv
Removing previously created '.X*-lock' entries under /tmp before starting Weston. Pass 'IGNORE_X_LOCKS=1' environment variable to Weston container to disable this behavior.
dos2unix: converting file /etc/xdg/weston/weston.ini to Unix format...
dos2unix: converting file /etc/xdg/weston-dev/weston.ini to Unix format...
00:00:00.000 [INFO] [seatd/seat.c:39] Created VT-bound seat seat0
00:00:00.000 [INFO] [seatd/seatd.c:194] seatd started
Date: 2025-03-17 UTC
[15:20:12.248] weston 10.0.1
https://wayland.freedesktop.org
Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
Build: lf-5.15.52-2.1.0-10-g9452feba
[15:20:12.249] Command line: weston -Bdrm-backend.so --current-mode -Swayland-0
[15:20:12.249] OS: Linux, 6.6.54-7.1.0-g3493ccd66900, #1-Torizon SMP PREEMPT Tue Dec 17 21:04:41 UTC 2024, aarch64
[15:20:12.249] Flight recorder: enabled
[15:20:12.251] Using config file '/etc/xdg/weston/weston.ini'
[15:20:12.255] Output repaint window is 7 ms maximum.
[15:20:12.258] Loading module '/usr/lib/aarch64-linux-gnu/libweston-10/drm-backend.so'
[15:20:12.398] initializing drm backend
[15:20:12.398] Trying libseat launcher...
00:00:00.246 [INFO] [seatd/server.c:145] New client connected (pid: 31, uid: 1000, gid: 1000)
00:00:00.247 [INFO] [seatd/seat.c:170] Added client 7 to seat0
00:00:00.247 [INFO] [seatd/seat.c:480] Opened client 7 on seat0
[15:20:12.401] libseat: session control granted
[15:20:12.406] using /dev/dri/card0
[15:20:12.407] DRM: supports atomic modesetting
[15:20:12.407] DRM: does not support GBM modifiers
[15:20:12.407] DRM: supports picture aspect ratio
[15:20:12.409] Loading module '/usr/lib/aarch64-linux-gnu/libweston-10/gl-renderer.so'
[15:20:12.500] EGL client extensions: EGL_EXT_client_extensions
EGL_EXT_platform_base EGL_KHR_platform_wayland
EGL_EXT_platform_wayland EGL_EXT_device_query
EGL_EXT_device_drm EGL_EXT_device_drm_render_node
EGL_KHR_platform_gbm
[15:20:12.501] failed to initialize display
[15:20:12.501] EGL error state: EGL_NOT_INITIALIZED (0x3001)
[15:20:12.501] failed to initialize egl
00:00:00.348 [INFO] [seatd/seat.c:418] No clients on seat0 to activate
00:00:00.349 [INFO] [seatd/seat.c:524] Closed client 7 on seat0
00:00:00.349 [INFO] [seatd/seat.c:192] Removed client 7 from seat0
00:00:00.349 [INFO] [seatd/client.c:471] Client disconnected
[15:20:12.502] fatal: failed to create compositor backend
Internal warning: debug scope 'drm-backend' has not been destroyed.
00:00:00.371 [INFO] [seatd/seatd.c:218] seatd stopped
Switching back to vt 1
Switching to VT 7
SoC is: 'i.MX8MM'
SoC has GPU: true
SoC has DPU: false
[15:20:13.582] weston 10.0.1
[15:20:13.583] Command line: weston -Bdrm-backend.so --current-mode -Swayland-0
[15:20:13.583] OS: Linux, 6.6.54-7.1.0-g3493ccd66900, #1-Torizon SMP PREEMPT Tue Dec 17 21:04:41 UTC 2024, aarch64
[15:20:13.583] Flight recorder: enabled
[15:20:13.583] Using config file '/etc/xdg/weston/weston.ini'
[15:20:13.584] Output repaint window is 7 ms maximum.
[15:20:13.584] Loading module '/usr/lib/aarch64-linux-gnu/libweston-10/drm-backend.so'
[15:20:13.604] initializing drm backend
[15:20:13.604] Trying libseat launcher...
00:00:00.066 [INFO] [seatd/server.c:145] New client connected (pid: 28, uid: 1000, gid: 1000)
00:00:00.069 [INFO] [seatd/seat.c:170] Added client 7 to seat0
00:00:00.070 [INFO] [seatd/seat.c:480] Opened client 7 on seat0
[15:20:13.613] libseat: session control granted
[15:20:13.624] using /dev/dri/card0
[15:20:13.625] DRM: supports atomic modesetting
[15:20:13.625] DRM: does not support GBM modifiers
[15:20:13.625] DRM: supports picture aspect ratio
[15:20:13.625] Loading module '/usr/lib/aarch64-linux-gnu/libweston-10/gl-renderer.so'
[15:20:13.643] EGL client extensions: EGL_EXT_client_extensions
[15:20:13.644] failed to initialize display
[15:20:13.644] EGL error state: EGL_NOT_INITIALIZED (0x3001)
[15:20:13.644] failed to initialize egl
00:00:00.102 [INFO] [seatd/seat.c:418] No clients on seat0 to activate
00:00:00.103 [INFO] [seatd/seat.c:524] Closed client 7 on seat0
00:00:00.103 [INFO] [seatd/seat.c:192] Removed client 7 from seat0
00:00:00.103 [INFO] [seatd/client.c:471] Client disconnected
[15:20:13.646] fatal: failed to create compositor backend
00:00:00.110 [INFO] [seatd/seatd.c:218] seatd stopped
Switching to VT 7
SoC is: 'i.MX8MM'
SoC has GPU: true
SoC has DPU: false
[15:20:14.641] weston 10.0.1
[15:20:14.641] Command line: weston -Bdrm-backend.so --current-mode -Swayland-0
[15:20:14.641] OS: Linux, 6.6.54-7.1.0-g3493ccd66900, #1-Torizon SMP PREEMPT Tue Dec 17 21:04:41 UTC 2024, aarch64
[15:20:14.641] Flight recorder: enabled
[15:20:14.642] Using config file '/etc/xdg/weston/weston.ini'
[15:20:14.642] Output repaint window is 7 ms maximum.
[15:20:14.643] Loading module '/usr/lib/aarch64-linux-gnu/libweston-10/drm-backend.so'
[15:20:14.655] initializing drm backend
[15:20:14.655] Trying libseat launcher...
00:00:00.052 [INFO] [seatd/server.c:145] New client connected (pid: 28, uid: 1000, gid: 1000)
00:00:00.053 [INFO] [seatd/seat.c:170] Added client 7 to seat0
00:00:00.053 [INFO] [seatd/seat.c:480] Opened client 7 on seat0[15:20:14.657] libseat: session control granted
[15:20:14.661] using /dev/dri/card0
[15:20:14.662] DRM: supports atomic modesetting
[15:20:14.662] DRM: does not support GBM modifiers
[15:20:14.662] DRM: supports picture aspect ratio
[15:20:14.662] Loading module '/usr/lib/aarch64-linux-gnu/libweston-10/gl-renderer.so'
[15:20:14.674] EGL client extensions: EGL_EXT_client_extensions
[15:20:14.674] failed to initialize display
[15:20:14.674] EGL error state: EGL_NOT_INITIALIZED (0x3001)
[15:20:14.674] failed to initialize egl
00:00:00.070 [INFO] [seatd/seat.c:418] No clients on seat0 to activate
00:00:00.071 [INFO] [seatd/seat.c:524] Closed client 7 on seat0
00:00:00.071 [INFO] [seatd/seat.c:192] Removed client 7 from seat0
00:00:00.071 [INFO] [seatd/client.c:471] Client disconnected
[15:20:14.675] fatal: failed to create compositor backend
00:00:00.076 [INFO] [seatd/seatd.c:218] seatd stopped
Switching to VT 7
SoC is: 'i.MX8MM'
SoC has GPU: true
SoC has DPU: false
[15:20:15.797] weston 10.0.1
[15:20:15.798] Command line: weston -Bdrm-backend.so --current-mode -Swayland-0
[15:20:15.798] OS: Linux, 6.6.54-7.1.0-g3493ccd66900, #1-Torizon SMP PREEMPT Tue Dec 17 21:04:41 UTC 2024, aarch64
[15:20:15.798] Flight recorder: enabled
[15:20:15.798] Using config file '/etc/xdg/weston/weston.ini'
[15:20:15.799] Output repaint window is 7 ms maximum.
[15:20:15.799] Loading module '/usr/lib/aarch64-linux-gnu/libweston-10/drm-backend.so'
[15:20:15.812] initializing drm backend
[15:20:15.812] Trying libseat launcher...
00:00:00.051 [INFO] [seatd/server.c:145] New client connected (pid: 29, uid: 1000, gid: 1000)
00:00:00.052 [INFO] [seatd/seat.c:170] Added client 7 to seat0
00:00:00.052 [INFO] [seatd/seat.c:480] Opened client 7 on seat0
[15:20:15.813] libseat: session control granted
[15:20:15.818] using /dev/dri/card0
[15:20:15.818] DRM: supports atomic modesetting
[15:20:15.818] DRM: does not support GBM modifiers
[15:20:15.818] DRM: supports picture aspect ratio
[15:20:15.818] Loading module '/usr/lib/aarch64-linux-gnu/libweston-10/gl-renderer.so'
[15:20:15.831] EGL client extensions: EGL_EXT_client_extensions
[15:20:15.831] failed to initialize display
[15:20:15.831] EGL error state: EGL_NOT_INITIALIZED (0x3001)
[15:20:15.831] failed to initialize egl
00:00:00.071 [INFO] [seatd/seat.c:418] No clients on seat0 to activate
00:00:00.072 [INFO] [seatd/seat.c:192] Removed client 7 from seat0
00:00:00.072 [INFO] [15:20:15.833] fatal: failed to create compositor backend
Switching to VT 7
SoC is: 'i.MX8MM'
SoC has GPU: true
SoC has DPU: false
[15:20:17.335] weston 10.0.1
[15:20:17.335] Command line: weston -Bdrm-backend.so --current-mode -Swayland-0
[15:20:17.336] OS: Linux, 6.6.54-7.1.0-g3493ccd66900, #1-Torizon SMP PREEMPT Tue Dec 17 21:04:41 UTC 2024, aarch64
[15:20:17.336] Flight recorder: enabled
[15:20:17.336] Using config file '/etc/xdg/weston/weston.ini'
[15:20:17.337] Output repaint window is 7 ms maximum.
[15:20:17.338] Loading module '/usr/lib/aarch64-linux-gnu/libweston-10/drm-backend.so'
[15:20:17.352] initializing drm backend
[15:20:17.352] Trying libseat launcher...
00:00:00.058 [INFO] [seatd/server.c:145] New client connected (pid: 29, uid: 1000, gid: 1000)
00:00:00.058 [INFO] [seatd/seat.c:170] Added client 7 to seat0
00:00:00.059 [INFO] [seatd/seat.c:480] Opened client 7 on seat0
[15:20:17.354] libseat: session control granted
[15:20:17.359] using /dev/dri/card0
[15:20:17.359] DRM: supports atomic modesetting
[15:20:17.359] DRM: does not support GBM modifiers
[15:20:17.359] DRM: supports picture aspect ratio
[15:20:17.359] Loading module '/usr/lib/aarch64-linux-gnu/libweston-10/gl-renderer.so'
[15:20:17.372] EGL client extensions: EGL_EXT_client_extensions
[15:20:17.373] failed to initialize display
[15:20:17.373] EGL error state: EGL_NOT_INITIALIZED (0x3001)
[15:20:17.373] failed to initialize egl
00:00:00.078 [INFO] [seatd/seat.c:418] No clients on seat0 to activate
00:00:00.078 [INFO] [seatd/seat.c:524] Closed client 7 on seat0
00:00:00.078 [INFO] [seatd/seat.c:192] Removed client 7 from seat0
00:00:00.078 [INFO] [seatd/client.c:471] Client disconnected
[15:20:17.373] fatal: failed to create compositor backend
00:00:00.084 [INFO] [seatd/seatd.c:218] seatd stopped
Switching to VT 7
SoC is: 'i.MX8MM'
SoC has GPU: true
SoC has DPU: false
My docker compose file docker-compose.yml:
services:
demoui:
image: renatom/demoui:latest
restart: always
depends_on:
- weston
networks:
- demo_network
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /var/run/dbus
target: /var/run/dbus
device_cgroup_rules:
# ... for tty
- "c 4:* rmw"
# ... for /dev/input devices
- "c 13:* rmw"
- "c 199:* rmw"
# ... for /dev/dri devices
- "c 226:* rmw"
weston:
image: commontorizon/weston-imx8:3.3.2
restart: always
environment:
- ACCEPT_FSL_EULA=1
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /run/udev
target: /run/udev
- type: bind
cap_add:
- CAP_SYS_TTY_CONFIG
# ... for tty
- "c 4:* rmw"
- "c 13:* rmw"
- "c 199:* rmw"
- "c 226:* rmw"
networks:
demo_network:
driver: bridge # Default network type
Yes, my Development Board has the DSI to HDMI coverter installed and it works fine (tested when I was installing the Torizon OS)
Help appreciated to solve this.
