When creating a new project with VS2015 and using the standard project templates from the Toradex_CE800 SDK wrong preprocessor definitions are set in the release configuration. Is there an issue in the Toradex_CE800 SDK?
This is issue of files provided by Microsoft. We opened a ticket with them and they documented it as known issue.
You can find documentation on this website → https://www.microsoft.com/en-us/download/details.aspx?id=42027
if you press download and select file “Windows Embedded Compact 2013_Update53.htm”
