WEC2013 Lib V2.1 crahes when calling Imx7I2c_Write()
after updating to CE lib version 2.1 we’re getting a crash when calling Imx7I2c_Write(). With CE Lib V2.0 there is all ok.
We init the first I2C-Channel with Standard Pins (196/194): [upload|3I94+m/jHW4NEloMceg1bXrdEIc=]
[upload|45wCLF0cvRyWwEvu8bW/sX6GR08=]
Do you have any suggestions?
We will check this and provide you an update tomorrow.
Can you include line numbers and file names in your screenshot?
I quickly cheched the code. I assume the problem is related to the fact that I2C_write with a NULL data and 0 size does not work any longer. I suggest you to use the following scan function:
/// Scan I2C Bus for available devices.
/// @param[in]  i2c           HANDLE to I2C port, retrieved from I2c_Init()
void i2cScan(HANDLE i2c)
	int i, count = 0;
	BOOL Success;
	Success = I2c_Open(i2c);
	if (!Success)
		printf("I2c_Open failed. Exit Scan", count);
		return;
	printf("Scanning i2c bus...\r\n");
	for (i = 8; i < 0x78; i++) // First and last 8 addresses are reserved
		BYTE tmpBuf;
		I2c_SetConfigInt(i2c, TEXT("SlaveAddr"), i, StoreVolatile);
		Success = (I2c_Read(i2c, &tmpBuf, 1) == (DWORD)-1) ? FALSE : TRUE;
		if (Success)
			printf("- 0x%02x \n\r", i);
			count++;
		//Sleep(1);
	I2c_Close(i2c);
	printf("\r\n%d device(s) found.\r\n", count);
We will fix the demo code in the next library release.
After changing the scan function, it is now running again. Thanks samuel.tx.
