Hi
I have been following the steps in the Toradex webnair (part 1).
Webinar On-Demand: Part 1 Introduction - Building Embedded Linux Images with the Yocto Project
My host machine is ubuntu 14.04 (64).
I am able to run the following command successfully (no errors).
bitbake -k angstrom-lxde-image
I would like to build an image that contains nginx webserver.
I have added the line below to my local.conf file.
IMAGE_INSTALL += “nginx”
But my build fails after adding that line to the local.conf file.
ERROR: Nothing RPROVIDES ‘nginx’
Any support or suggestion would be appreciated.
