Hello!
I am trying to use the WebRTC protocol in Firefox (v.52). A microphone and headphones are connected, but the system gives an error: “Error getting user media: audio / or video is required
getUserMedia error: Failed to get access to local media. Error name NotSupportedError. Continuing without sending a stream”.
When I try to test microphone in some testing web site I’m give: Permission denied.
Speackers don’t work.
How to fix?
Thanks.
Could you provide the version of the Hardware (including Carrier Board) and Software of your module?
We use our own electronic circuit board. It has an audio input (for microphone) and an audio output (for headphones). A collibri card is inserted into the central slot of our board. This equipment has been operating on buses for several years. We used to use Windows, but now we are switching to Linux. Linux is a custom version of Angstrom Yocto (Colibri-imx-emmc 4.9.87-2.8.4+g3bb6e32 armv7l).
What is your application? What are you trying to do?
I’m trying to use www.appr.tc room for connecting but no sucssesful. If the equipment works, I will write a WebRTC program for communication between the bus driver and the dispatcher.
I am testing equipment at www.bigmarker.com.
I see that the browser has an add-on for WebRTC support: “OpenH264 Video Codec provided by Cisco Systems inc. will be installed shortly”.
How to see if Pulsaudio is on?
