I’m trying to activate webdav in wince6 (Toradex VF61). I’m using that documentation : WebDAV (Windows Embedded CE 6.0) | Microsoft Docs but unfortunately, it doesn’t work. Here are the registry :
Did I miss something ? It’s obviously uncomplete.
P.S. : accessing http:///directory is working : I can see the content of \www\test.
But WebDAV test failed : “Command not implemented (OPTIONS /directory 501)”
Unfortunately the WebDAV component is not included in our standard Image, so if you need that functionality you need to build your own Image with Platform Builder and our Workspace + BSP packages.
Thank you very much for your answer. I tried the way you indicate but unfortunately, I don’t know how to install PlatForm Builder for winCE 6.0 on visual studio (2008 in my case). … Is there a PlateForm Builder for visual studio 2008 and where ?
Thank you for your answer ! Unfortunately, this msi is for Visual Studio 2005 Only… It doesn’t complete with Visual Studio 2008… Argh …
If you have an idea…
Hi @ANSEL ,
If the issue is only the Visual Studio, you can install Windows CE 6.0 also without Visual Studio. You can then either use it in command line build mode, or do it like we do here at Toradex and use VS2008 + PlatformBuilder for CE7 to open CE6 workspaces. This works for us so we don’t need to use VS2005 anymore.
OK I have succeeded in installing PlatForm Builder in VS 2008 ! But Now I need a valid WINCEROOT image for ARMV4l architecture… I don’t know where I can find it… Is it possible to download one please ?
If you need to have a bigger Image you can reduce the area reserved for flashdisk. This is a bit more complicated as you also need to shift the registry location. Take a look at this article:
