We have a custom board made based on Apalis T30 SoC. And Linux is running on the board.
Kernel version : 3.1.10-g8e1745b-dirty
We want to run mysql server on the board and we have no clue to add it on our custom board.
I would be great if I get help on this.
Thanks,
Shiva Shankar K.
Apalis T30 module that is.
That looks like the Linux kernel from BSP 2.8b1 with some customisation.
Please note that BSP 2.8b1 is considered obsolete and you should update to our latest beta BSP 2.8b2 at your earliest convenience.
You could build a custom image which adds MySQL e.g. by adding the following to your conf/local.conf
IMAGE_INSTALL_append = " mysql5"
Note the space in front of mysql5.
You are very welcome.
Dear Marcel,
Thanks for your inputs.
I will get back to you after verifying this.
Shiva Shankar K.
You are welcome. Regards, Jaski
