Hi team,
A customer asked me that they want to show the video in fullscreen. Currently the desktop bar is showing:
How should we do this? Stop the Window Manager before playing the video? Show the video on fullscreen through some extra command in Gstreamer?
Currently we are using the following command (I also tried disabling the Qt Cinematic demo, same result):
gst-launch-1.0 filesrc location=testvideo_h264.mp4 ! video/quicktime ! aiurdemux ! h264parse ! v4l2h264dec ! imxvideoconvert_g2d ! autovideosink
Thanks!
Hi @alvaro.tx
On option would be to remove the panel from weston entirely. Just add the following line to /etc/xdg/weston/weston.ini:
[shell]
panel-position=none
Afterwards you need to restart weston:
systemctl restart weston@root
Stefan
Thanks Stefan, that worked like a charm
@stefan_e.tx , do you also know how to make the application “full-screen”, e.g. without the minimize/close buttons? Something similar to what “kiosk” is capable to do.
svogl
January 22, 2021, 8:54am
5
According to our experience, editing the panel position is not enough, as the waylandsik gstreamer plugin has a hard-coded size setting. We got rid of this with the following patch:
diff --git a/ext/wayland/wlutils.c b/ext/wayland/wlutils.c
index a4d4399a3..404eedff9 100644
--- a/ext/wayland/wlutils.c
+++ b/ext/wayland/wlutils.c
@@ -131,7 +131,7 @@ gst_wl_init_surface_state(GstWlDisplay * display, GstWlWindow * window)
goto out;
window->fullscreen_width = desktop_width;
- window->fullscreen_height = desktop_height - PANEL_HEIGH;
+ window->fullscreen_height = desktop_height;// - PANEL_HEIGH;
} else {
ret = FALSE;
goto out;
@@ -144,4 +144,4 @@ out:
g_free (size);
fclose(fp);
return ret;
\ No newline at end of file
diff --git a/ext/wayland/wlwindow.c b/ext/wayland/wlwindow.c
index 4d1c1fcd8..9a39dbe0b 100644
--- a/ext/wayland/wlwindow.c
+++ b/ext/wayland/wlwindow.c
@@ -166,7 +166,7 @@ gst_wl_window_new_internal (GstWlDisplay * display, GMutex * render_lock)
if (!gst_wl_init_surface_state(display, window)) {
window->fullscreen_width = display->width;
- window->fullscreen_height = display->height - PANEL_HEIGH;
+ window->fullscreen_height = display->height;// - PANEL_HEIGH;
window->scale = 1;
GST_WARNING ("init surface_state fail, fallback to scale=%d fullscreen (%dx%d)",
window->scale,
and a gstreamer1.0-plugins-bad_1.14.imx.bbappend file:
FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
SRC_URI += "\
file://screensize.patch \
Any feedbacks on that @stefan_e.tx ?
Hi @svogl
Which BSP version are you using? I think the wlutils.c file is only there in gstreamer1.0-plugins-bad_1.14. With zeus (BSP3.0) and dunfell (BSP5.0) it should be different (1.16). Maybe it was just an issue on that specific version?
Stefan
svogl
January 26, 2021, 3:43pm
8
the 1.14 patch is from an older BSP (thud / 2.8); I had a look at what dunfell is doing: the plugin upgraded to 1.16, the wayland code looks the same and the patch applies flawlessly.
Simon
Hi @svogl ,
Nice! Thanks for the feedback.
André Curvello
karim
March 23, 2021, 6:16pm
10
Is there any update for this subject ?
I’m experiencing the same issue, that is,
[shell]
panel-position=none
It’s not enough, indeed. There’s still a kind of bar on the top and bottom.
I’ve also applied the patch above…but it doesn’t work much better.
Am I missing something ?
Karim
Hi @karim ,
Can you share a picture of this?
And, which GUI Framework are you using for your Graphical application?
André Curvello.
karim
March 24, 2021, 7:38am
12
Hi @andrecurvello.tx
Please find attached a camera picture (sorry for the sun reflections).
You can a kind of border on top & bottom.
I’m using a toradex multimedia reference image with gstreamer playback using waylandsink. No custom modifications in this image.
Karim
Ok.
Can you take another picture?
And I’ll ask you to open another thread here on Toradex Community.
Could be that your problem is the same as this topic, or it’s something else.
Can you create the post and send the link here?
Please provide as much information as possible:
Which module are you using
Which carrier board are you using
Which TorizonCore are you using
André Curvello
When I executed the systemctl restart weston@root command, I encountered the following error message:
root@apalis-imx8-07013853:~# systemctl restart weston@root
Failed to restart weston@root.service: Unit weston@root.service not found.
However, after executing the systemctl restart weston.service command, the desktop bar was successfully removed.
