Watchdog issue
Hi all,
i got an issue trying to use the watchdog on linux. I followed the example given in High performance, low power | Footprint for embedded computing
to test the watchdog reboot. So I commented out the send_magic() call, ran the program, gave Ctrl+C and waited.
After 60 secs the system restarts but It hangs during booting, on the line “cpu-tegra: init EDP limit: 1250 MHz”.
Triggering the module RESET pin works well, what a I doing wrong??
Thanks all!
What exact BSP version are you talking about? I suspect that what you are seeing is the following issue already fixed in our latest BSP 2.7b3.
I am using the binary image “Colibri_T30_LinuxImageV2.6_20160826.tar.bz2”.
Following your link it seems I have to update the bootloader, am I right?
Yes, correct. Just updating the boot loader should suffice.
Ok, I have updated the boot loader and it works fine now!
Thanks for the help!
