Trying to install the google cloud in toradex board for speech to text conversion.
And need to install the ‘pyaudio’ dependency package.
pip install pyaudio
Getting the ‘portaudio’ library not found error while installing the pyaudio.
And now cross compiled the portaudio (pa_stable_v190600_20161030.tgz) and placed the libraries in ‘/usr/lib/’.
But now getting different linker error while installing the pyaudio.
Also I have tried to install this package ‘python-audio’ & ‘portaudio-v19’ via yocto, still it says ‘pyaudio’ not found.
Can you please help me to install the pyaudio in toradex board ?
(env) root@apalis-imx6:/# pip install pyaudio
Collecting pyaudio
Using cached PyAudio-0.2.11.tar.gz
Building wheels for collected packages: pyaudio
Running setup.py bdist_wheel for pyaudio ... error
Complete output from command /env/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-iNp6BF/pyaudio/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpnk9Eoxpip-wheel- --python-tag cp27:
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-2.7
copying src/pyaudio.py -> build/lib.linux-armv7l-2.7
running build_ext
building '_portaudio' extension
creating build/temp.linux-armv7l-2.7
creating build/temp.linux-armv7l-2.7/src
arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -fno-strict-aliasing -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/saro/workdir/Titus/yocto_toradexApalis_imx6/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/python/2.7.12-r1=/usr/src/debug/python/2.7.12-r1 -fdebug-prefix-map=/home/saro/workdir/Titus/yocto_toradexApalis_imx6/oe-core/build/tmp-glibc/sysroots/x86_64-linux= -fdebug-prefix-map=/home/saro/workdir/Titus/yocto_toradexApalis_imx6/oe-core/build/tmp-glibc/sysroots/apalis-imx6= -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c src/_portaudiomodule.c -o build/temp.linux-armv7l-2.7/src/_portaudiomodule.o
In file included from /usr/include/python2.7/Python.h:8:0,
from src/_portaudiomodule.c:28:
/usr/include/python2.7/pyconfig.h:1193:0: warning: "_POSIX_C_SOURCE" redefined
#define _POSIX_C_SOURCE 200112L
In file included from /usr/include/stdio.h:27:0,
from src/_portaudiomodule.c:27:
/usr/include/features.h:225:0: note: this is the location of the previous definition
# define _POSIX_C_SOURCE 200809L
arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -shared -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed build/temp.linux-armv7l-2.7/src/_portaudiomodule.o -L/usr/lib -lportaudio -lpython2.7 -o build/lib.linux-armv7l-2.7/_portaudio.so
/usr/lib/gcc/arm-angstrom-linux-gnueabi/6.2.1/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: /usr/lib/libportaudio.a(pa_front.o): requires unsupported dynamic reloc R_ARM_MOVW_ABS_NC; recompile with -fPIC
/usr/lib/gcc/arm-angstrom-linux-gnueabi/6.2.1/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: /usr/lib/libportaudio.a(pa_unix_util.o): requires unsupported dynamic reloc R_ARM_MOVW_ABS_NC; recompile with -fPIC
/usr/lib/gcc/arm-angstrom-linux-gnueabi/6.2.1/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: /usr/lib/libportaudio.a(pa_debugprint.o): requires unsupported dynamic reloc R_ARM_MOVW_ABS_NC; recompile with -fPIC
/usr/lib/gcc/arm-angstrom-linux-gnueabi/6.2.1/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: /usr/lib/libportaudio.a(pa_unix_oss.o): requires unsupported dynamic reloc R_ARM_MOVW_ABS_NC; recompile with -fPIC
/usr/lib/gcc/arm-angstrom-linux-gnueabi/6.2.1/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: /usr/lib/libportaudio.a(pa_converters.o): requires unsupported dynamic reloc R_ARM_MOVW_ABS_NC; recompile with -fPIC
/usr/lib/gcc/arm-angstrom-linux-gnueabi/6.2.1/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: /usr/lib/libportaudio.a(pa_cpuload.o): requires unsupported dynamic reloc R_ARM_MOVW_ABS_NC; recompile with -fPIC
/usr/lib/gcc/arm-angstrom-linux-gnueabi/6.2.1/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: /usr/lib/libportaudio.a(pa_process.o): requires unsupported dynamic reloc R_ARM_MOVW_ABS_NC; recompile with -fPIC
collect2: error: ld returned 1 exit status
error: command 'arm-angstrom-linux-gnueabi-gcc' failed with exit status 1
Failed building wheel for pyaudio
Running setup.py clean for pyaudio
Failed to build pyaudio
Installing collected packages: pyaudio
Running setup.py install for pyaudio ... error
Complete output from command /env/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-iNp6BF/pyaudio/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-63Y3_q-record/install-record.txt --single-version-externally-managed --compile --install-headers /env/include/site/python2.7/pyaudio:
running install
running build
running build_py
creating build
running build_ext
Command "/env/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-iNp6BF/pyaudio/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-63Y3_q-record/install-record.txt --single-version-externally-managed --compile --install-headers /env/include/site/python2.7/pyaudio" failed with error code 1 in /tmp/pip-build-iNp6BF/pyaudio/
