Hi!
Yesterday I was developing a Qt C++/QML app with VSCode (on Linux), and after adding a library to the dev container, I tried to rebuild the SDK (for the first time after some days without adding any library) but it failed. I tried with a new project, but the error was the same. Today, I am using a different computer (Windows), and after creating a new basic Qt QML project, it fails with the same error:
Step 1/4 : FROM torizon/debian-cross-toolchain-arm64:2-bullseye
---> f278eed1d519
Step 2/4 : RUN HOLD_PKGS='libdrm-common libdrm-amdgpu1:arm64 libdrm2:arm64' && apt-get -y update && apt-get -y upgrade && for P in $HOLD_PKGS ; do echo ${P}=$(apt-cache show $P | sed -r -e '/^Version:/!d' -e 's/.* //' -e '/toradex/d' -e 'q') ; done | xargs -r apt-get install -y --no-install-recommends && apt-mark hold $HOLD_PKGS && apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
---> Running in cce134e603b4
Get:1 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye InRelease [142 kB]
Get:2 https://feeds.toradex.com/debian/snapshots/20210525T091852Z testing InRelease [13.0 kB]
Get:3 https://feeds.toradex.com/debian/snapshots/20210525T091852Z testing/non-free arm64 Packages [13.1 kB]
Get:4 https://feeds.toradex.com/debian/snapshots/20210525T091852Z testing/main arm64 Packages [135 kB]
Get:5 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye-updates InRelease [40.1 kB]
Get:6 http://snapshot.debian.org/archive/debian-security/20210408T000000Z bullseye-security InRelease [44.1 kB]
Get:7 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye/main arm64 Packages [8088 kB]
Get:8 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye/main amd64 Packages [8201 kB]
Get:9 http://snapshot.debian.org/archive/debian-security/20210408T000000Z bullseye-security/main arm64 Packages [808 B]
Get:10 http://snapshot.debian.org/archive/debian-security/20210408T000000Z bullseye-security/main amd64 Packages [812 B]
Fetched 16.7 MB in 35s (474 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
Calculating upgrade...
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
The following additional packages will be installed:
gcc-10-base:arm64 libc6:arm64 libcrypt1:arm64 libgcc-s1:arm64
Suggested packages:
glibc-doc:arm64 libc-l10n:arm64 locales:arm64
Recommended packages:
libidn2-0:arm64 libnss-nis:arm64 libnss-nisplus:arm64
The following NEW packages will be installed:
gcc-10-base:arm64 libc6:arm64 libcrypt1:arm64 libdrm-amdgpu1:arm64
libdrm-common libdrm2:arm64 libgcc-s1:arm64
0 upgraded, 7 newly installed, 0 to remove and 0 not upgraded.
Need to get 2869 kB of archives.
After this operation, 11.4 MB of additional disk space will be used.
Get:1 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye/main arm64 gcc-10-base arm64 10.2.1-6 [201 kB]
Get:2 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye/main arm64 libgcc-s1 arm64 10.2.1-6 [34.6 kB]
Get:3 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye/main arm64 libcrypt1 arm64 1:4.4.17-1 [89.3 kB]
Get:4 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye/main arm64 libc6 arm64 2.31-11 [2460 kB]
Get:5 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye/main amd64 libdrm-common all 2.4.104-1 [14.9 kB]
Get:6 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye/main arm64 libdrm2 arm64 2.4.104-1 [41.3 kB]
Get:7 http://snapshot.debian.org/archive/debian/20210408T000000Z bullseye/main arm64 libdrm-amdgpu1 arm64 2.4.104-1 [28.0 kB]
e[91mdebconf: delaying package configuration, since apt-utils is not installed
e[0m
Fetched 2869 kB in 21s (137 kB/s)
Selecting previously unselected package gcc-10-base:arm64.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 21512 files and directories currently installed.)
Preparing to unpack .../0-gcc-10-base_10.2.1-6_arm64.deb ...
Unpacking gcc-10-base:arm64 (10.2.1-6) ...
Selecting previously unselected package libgcc-s1:arm64.
Preparing to unpack .../1-libgcc-s1_10.2.1-6_arm64.deb ...
Unpacking libgcc-s1:arm64 (10.2.1-6) ...
Selecting previously unselected package libcrypt1:arm64.
Preparing to unpack .../2-libcrypt1_1%3a4.4.17-1_arm64.deb ...
Unpacking libcrypt1:arm64 (1:4.4.17-1) ...
Selecting previously unselected package libc6:arm64.
Preparing to unpack .../3-libc6_2.31-11_arm64.deb ...
Unpacking libc6:arm64 (2.31-11) ...
Selecting previously unselected package libdrm-common.
Preparing to unpack .../4-libdrm-common_2.4.104-1_all.deb ...
Unpacking libdrm-common (2.4.104-1) ...
Selecting previously unselected package libdrm2:arm64.
Preparing to unpack .../5-libdrm2_2.4.104-1_arm64.deb ...
Unpacking libdrm2:arm64 (2.4.104-1) ...
Selecting previously unselected package libdrm-amdgpu1:arm64.
Preparing to unpack .../6-libdrm-amdgpu1_2.4.104-1_arm64.deb ...
Unpacking libdrm-amdgpu1:arm64 (2.4.104-1) ...
Setting up gcc-10-base:arm64 (10.2.1-6) ...
Setting up libdrm-common (2.4.104-1) ...
Setting up libcrypt1:arm64 (1:4.4.17-1) ...
Setting up libgcc-s1:arm64 (10.2.1-6) ...
Setting up libc6:arm64 (2.31-11) ...
Setting up libdrm2:arm64 (2.4.104-1) ...
Setting up libdrm-amdgpu1:arm64 (2.4.104-1) ...
Processing triggers for libc-bin (2.31-11) ...
libdrm-common set on hold.
libdrm-amdgpu1:arm64 set on hold.
libdrm2:arm64 set on hold.
---> 66f8644a05c2
Step 3/4 : RUN apt-get -q -y update && apt-get -q -y install gdb-multiarch procps rsync openssh-client qt5-qmake:arm64 qtbase5-dev:arm64 qtdeclarative5-dev:arm64 libegl-dev:arm64 libgl-dev:arm64 && rm -rf /var/lib/apt/lists/*
---> Running in 96c905f4001c
Fetched 16.7 MB in 58s (287 kB/s)
openssh-client is already the newest version (1:8.4p1-5).
openssh-client set to manually installed.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
qtdeclarative5-dev:arm64 : Depends: libqt5qml5:arm64 (= 5.14.2+dfsg-3)
Depends: libqt5quick5:arm64 (= 5.14.2+dfsg-3) or
libqt5quick5-gles:arm64 (= 5.14.2+dfsg-2) but it is not going to be installed
Depends: libqt5quickparticles5:arm64 (= 5.14.2+dfsg-3) or
libqt5quickparticles5-gles:arm64 (= 5.14.2+dfsg-2) but it is not going to be installed
Depends: libqt5quickshapes5:arm64 (= 5.14.2+dfsg-3) but it is not going to be installed
Depends: libqt5quicktest5:arm64 (= 5.14.2+dfsg-3)
Depends: libqt5quickwidgets5:arm64 (= 5.14.2+dfsg-3)
e[91mE: Unable to correct problems, you have held broken packages.
e[0m
[06-25 12:46:41.939] Local docker exception.
[06-25 12:46:45.439] Error (534) - OS error: [Errno -2] Name or service not known
[06-25 12:46:45.439] OS error.
config.yaml file contents are:
devices:
common: []
debug: []
release: []
dockercomposefile:
common: ''
debug: ''
release: ''
extraparms:
common: {}
debug: {}
release: {}
images:
debug: sha256:d3d1067df1347dc62d54029c48f423691e662e46ef6f2dfafe17348b7d46ef2c
release: ''
modificationdate: '2021-06-18T21:18:09.120365'
networks:
common: []
debug: []
release: []
platformid: arm64v8-qt5-vivante-no-ssh_bullseye
ports:
common: {}
debug: {}
release: {}
privatekey: '-----BEGIN RSA PRIVATE KEY-----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-----END RSA PRIVATE KEY-----
props:
common:
appname: pruebaQt
arg: ''
buildcommands: ''
buildfiles: ''
command: ''
devpackages: qtdeclarative5-dev:#%platform.debian-arch%# libegl-dev:#%platform.debian-arch%#
libgl-dev:#%platform.debian-arch%#
env: ''
exename: pruebaQt
expose: ''
extrapackages: 'qml-module-qtquick2 qml-module-qtquick-window2 qml-module-qtquick-controls
qml-module-qtquick-controls2 '
language: c-cpp-nossh
preinstallcommands: ''
sdkpostinstallcommands: ''
sdkpreinstallcommands: ''
targetcommands: ''
targetfiles: ''
debug:
arg: 'ARG SSHUSERNAME=#%application.username%#
release: {}
publickey: ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDQ9lD/Y6F/MTtlFX9MbLOZyQ1Dqiy++pdN3N8mLSsHmj0I9KVk2pGOpWe7v3it077YG9wJQSzEN0SL6vrF3oOgC887o3OJ7mB4DzWbFRPmutbla4zmT25UKQxW0Czjvwry1Y2/Ry3ilbMfRzKnRWaUTGUY5zUSl8rZRAJFC92dBJSiovM4w0RX2roS4UEI+/BtkPEWuYTt8GJFouKgASlZ5Qf63IkzIWitgb+zEhQistCPWRRXjHqSxm7sWcVSuRIZRDoJJgAl35C2CK3XWD8ZNr3FyKpu0bIp4950eEYHeI0fN036ViGLhPpzoPnGQjMb5m9ODqU5Bugd56b/qXNH
sdkimages:
debug: ''
release: sha256:2a836d8fbe9a0eeeb986dec92ef746b6bdf4f7285abe34ac3e810b4445a64045
sdksshaddress: null
shutdownscript:
common: ''
debug: ''
release: ''
startupscript:
common: ''
debug: ''
release: ''
username: torizon
volumes:
common: {}
debug:
/home/torizon/pruebaQt: /pruebaQt,rw
release: {}
I suspect there is a problem with Qt libraries, but it was compiling some days ago. Any insight in how can we solve this?
Thank you,
Tomás
