Hai, I’m running VS-Code with Torizon IDE Extension - Apollo X on the Ubuntu Platform and the Hardware was Colibri IMX6ULL 1GB with Colibri Evaluation Board.
As per the Quick start guide, I had completed the os installation and First Steps with Torizon. After that moving to the next step of developing application in Torizon, i did the steps as mentioned in the guide.
I had faced the issue when running the program,
Torizon: host-install-pip-requirements failed.
I had attached the image for the reference, Kindly check it and let me know the solution to this problem.
