I’m evaluation the Colibri iMX8DX 1GB with the goal to migrate our C# application currently running on a Colibri T30 with WinCE. I loaded VSCode with the new AppoloX extension.
When creating a new C# project from scratch, the host_ip setting in settings.json is incorrectly set to an IP from the wrong adapter:
settings.json
"torizon_psswd": "xyz",
"torizon_login": "torizon",
"torizon_ip": "192.168.1.202",
"host_ip": "169.254.145.175",
"torizon_workspace": "${workspaceFolder}",
The correct host IP should be 192.168.1.226. The 169.x is an autoconfig IP from another ethernet adapter (not on the same network).
ipconfig output:
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : xxxx
Link-local IPv6 Address . . . . . : fe80::dfca:959f:d9a7:38d0%7
IPv4 Address. . . . . . . . . . . : 192.168.1.226
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
Ethernet adapter Ethernet 2:
Autoconfiguration IPv4 Address. . : 169.254.145.175
Subnet Mask . . . . . . . . . . . : 255.255.0.0
I can manually change it to the right one (192.168.1.226), however this leads to another error when the module tries to pull the docker image from the host:
Warning: Permanently added '192.168.1.202' (ED25519) to the list of known hosts.
The DOCKER_LOGIN variable is not set. Defaulting to a blank string.
Pulling torizontest2-debug ...
Pulling torizontest2-debug ... error
ERROR: for torizontest2-debug Get "https://192.168.1.226:5002/v2/": http: server gave HTTP response to HTTPS client
Google pointed me to add "insecure-registries" : ["192.168.1.226:5002"] to my Docker Desktop instance, but I realised this error came from the module and not my host. I manually edited /etc/docker/daemon.json and it now work.
Is there a way to avoid this problem? When is the wrong IP fetched in the process?
