I am using “NAudio dll” for “VOIP” application that successfully build and deploy but on the time of debugging/run using Win CE Image Version 1.5
Board col. VF61 256MB IT V1.2B and carrier board IRIS Version 1.1A
Dear @hemantVaaaN,
Did you set any breakpoint in the application?
Is there any exception from OS image, this can be verified by seeing in the debug log messages.
I guess you are developing .NET application, Did you install .NET on the module?
application?
No we just deploy application using VS and try to debug without any breakpoints
debug log messages.
No exception
the module?
Yes its already installed compact framework 3.9 in collberray module
We using NAudio dll for transmitting the voice only, if we remove the dependency application working otherwise got the exception.
Dear @hemantVaaaN,
Could you please share reproducible demo application and details steps how to reproduce. It will help us to quickly look at the issue.
