just tried to run vncconfig on my WEC 2013, but Fails:
I load the Version for WEC2013 and follow strictly the article here
Thnaks a lot for helping
With best regards
Gerhard
With best regards
Gerhard
Dear @Gerhard
To optimize the image size, the msvcp110d.dll was one of the files which we removed from the standard image. You can find this .dll in the WEC2013 SDK
( C:\Program Files (x86)\Windows CE Tools\SDKs\Toradex_CE800\Sdk\Crt\bin\ARM or similar) .
Copy this file to the target system, into the folder \Flashdisk\System\. This should fix the problem.
Regards, Andy
Thanks Andy.
oops.
I found this dll and copied it as you told me, but no success. Same error as before.
Her the file listing:
Dear @Gerhard
Thank you. Please feel free to contact us if you require any support in future
Hi Raja,
sorry, but didn’t work out see please above comment.
With best regards
Gerhard
Hi @Gerhard
Please try to copy the msvcp110d.dll to the same folder as the application .exe is. Does it help?
Regards, Andy
No, sorry.
Dear @Gerhard,
Could you please keep msvcp110d.dll and msvcr110d.dll in the \Flashdisk\System\ or to the same folder where the application .exe is kept. Those files you find in the C:\Program Files (x86)\Windows CE Tools\SDKs\Toradex_CE800\Sdk\Crt\bin\ARM or download it from here.
Please let us know if it doesn’t help.
now it works. I used only the files …d.dll, but it seems, I Need all four dlls.
However, works now. Thanks.
With best regards
Gerhard
With best regards
Gerhard
