I have a docker container running an Electron application (React) together with the Weston compositor.
When enabling VNC and connecting, I can see the display, but cannot interact with either mouse or keyboard. Am I missing something from my docker-compose configuration?
Weston version is 3.2.2
Electron Version: 29.1.4
- Chromium: 122.0.6261.129
- Node.js: 20.9.0
- V8: 12.2.281.22
docker-compose:
services:
launcher:
image: xcel-launcher:${LAUNCHER_VERSION}
container_name: xcel-launcher
depends_on:
- weston
cap_add:
- CAP_SYS_ADMIN
- CAP_SYS_TTY_CONFIG
device_cgroup_rules:
- c 4:* rmw
- c 13:* rmw
- c 199:* rmw
- c 226:* rmw
devices:
- /dev/bus/usb:/dev/bus/usb
expose:
- 2228
- 9229
- 9223
- 631
network_mode: host
privileged: true
restart: always
ulimits:
nofile:
hard: 40000
soft: 20000
nproc: 65535
volumes:
- /tmp:/tmp
- /dev:/dev
# - ${USER_HOME}/app:/home/torizon/app # uncomment to run app on host
- /etc/localtime:/etc/localtime:ro
- ${USER_HOME}/flex/hosts:/etc/hosts
- ${USER_HOME}/PDF:/root/PDF
- ${USER_HOME}/staging:/root/staging
- ${USER_HOME}/install:/root/install
- ${USER_HOME}/launcher-config:/root/launcher-config
- cups:/etc/cups
- ${USER_HOME}/flex/cupsd.conf:/etc/cups/cupsd.conf
- /run/dbus:/run/dbus
profiles: [launcher, ui]
weston:
image: weston:${WESTON_VERSION}
container_name: weston
cap_add:
- c 4:* rmw
- c 13:* rmw
- c 199:* rmw
- c 226:* rmw
environment:
ACCEPT_FSL_EULA: "1"
ENABLE_VNC: "1"
network_mode: host
restart: always
volumes:
- /tmp:/tmp
- /dev:/dev
- /run/udev:/run/udev
profiles: [weston, ui]
tdx-info:
Software summary
Bootloader: U-Boot
Kernel version: 5.15.177-6.8.2+git.5a6602cc6c32 #1-TorizonCore SMP PREEMPT Fri Mar 21 16:22:58 UTC 2025
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/c3a7ca8ff2232a05598c6b02529fba8f0dbacced78ea6fbf3ecb16d59a72a05e/0
Distro name: NAME="TorizonCore"
Distro version: VERSION_ID=6.8.2-build.30
Distro variant: VARIANT="Docker"
Hostname: verdin-imx8mp-15504086
Hardware info
HW model: Toradex Verdin iMX8M Plus on Verdin Development Board
Toradex version: 0063 V1.1B
Serial number: 15504086
Processor arch: aarch64
Hello! Thank you for providing detailed information about your setup.
The issue you’re experiencing—where the VNC session displays your GUI but doesn’t respond to mouse or keyboard input—is almost always due to missing device access permissions in your Weston container. According to the Toradex VNC server setup documentation, one critical device rule is missing from your weston service.
Here’s what you need to update in your docker-compose.yml Weston service:
Add Missing Device Cgroup Rule
The Weston container must also have access to devices with major number 253 (used for input event handling by Weston). Add the following rule to your device_cgroup_rules:
- 'c 4:* rmw'
- 'c 13:* rmw'
- 'c 199:* rmw'
- 'c 226:* rmw'
- 'c 253:* rmw' # <--- Add this line
Ensure All Volume Mounts are Present
You already have the proper volume mounts, which is great:
volumes:
- /tmp:/tmp
- /dev:/dev
Use the Official Image (Recommended)
If possible, consider using the official Toradex Weston image for your module type (e.g., torizon/weston-imx8:$CT_TAG_WESTON) to ensure all dependencies and device access are set up correctly. This is suggested for the best compatibility, especially when using VNC.
Example Weston Section:
weston:
image: torizon/weston-imx8:$CT_TAG_WESTON
cap_add:
- 'c 4:* rmw'
- 'c 13:* rmw'
- 'c 199:* rmw'
- 'c 226:* rmw'
- 'c 253:* rmw'
environment:
ENABLE_VNC: "1"
network_mode: host
restart: always
volumes:
- /tmp:/tmp
- /dev:/dev
Reference:
Remote Access the TorizonCore GUI using VNC or RDP - Server Setup
Other Important Notes:
- VNC access is known to reduce GUI responsiveness. The impact depends on your application’s graphics demands.
- Ensure port 5900 is accessible to your VNC client.
- VNC is not supported on Torizon 7 at this time.
After making this change, restart your containers. Your VNC session should then accept both mouse and keyboard input.
Let me know if this solves your issue or if you need further assistance!
Modifying the docker-compose file and restarting the containers made no difference.
revised docker-compose:
services:
launcher:
depends_on:
- weston
cap_add:
- CAP_SYS_ADMIN
- 'c 4:* rmw'
- 'c 13:* rmw'
- 'c 199:* rmw'
- 'c 226:* rmw'
- 'c 253:* rmw'
devices:
expose:
- 2228
- 9229
- 9223
- 631
network_mode: host
privileged: true
restart: always
environment:
DISPLAY: ":1"
ulimits:
nofile:
hard: 40000
soft: 20000
nproc: 65535
volumes:
- /tmp:/tmp
- /dev:/dev
- cups:/etc/cups
weston:
image: torizon/weston-vivante:3.2.2
cap_add:
- 'c 4:* rmw'
- 'c 13:* rmw'
- 'c 199:* rmw'
- 'c 226:* rmw'
- 'c 253:* rmw'
environment:
ENABLE_VNC: "1"
DISPLAY: ":1"
network_mode: host
restart: always
volumes:
- /tmp:/tmp
- /dev:/dev
Hi @Steve_S!
I tested the following docker-compose.yaml, and I could both see my mouse and write with the keyboard. Could you please test it and see if it solves the issue?
version: "2.4"
services:
weston:
environment:
- ACCEPT_FSL_EULA=1
- ENABLE_VNC=1
network_mode: host
cap_add:
volumes:
- /dev:/dev
- /tmp:/tmp
- /run/udev/:/run/udev/
- 'c 4:* rmw'
- 'c 13:* rmw'
- 'c 199:* rmw'
- 'c 226:* rmw'
- 'c 253:* rmw'
command: --developer --tty=/dev/tty7
restart: unless-stopped
Thanks Lucas.
If I stop my launcher container, then yes, I can create a console window and interact with the UI of the Weston container.
I still cannot use mouse or keyboard when the launcher container (Electron App) is running and presenting it’s GUI.
I don’t know if this helps; here is my startup command for the Electron app:
/home/torizon/app/launcher --no-sandbox --enable-features=UseOzonePlatform --ozone-platform=wayland --use-gl=egl --in-process-gpu
Hi @Steve_S!
Just to clarify, did you write the xcel-launcher container, or did you use a pre-existing one?
I suspect that the issue is directly related to the launcher container (possibly a missing parameter), since you can use the mouse and keyboard with only Weston.
Best regards.
Hi Lucas,
I use a torizon/wayland-base-vivante image as my base, onto which I then copy my electron app.
The Dockerfile for the base image is here:
# ARGUMENTS --------------------------------------------------------------------
# Board architecture
ARG IMAGE_ARCH=${IMAGE_ARCH}
# For armv7 use:
#ARG IMAGE_ARCH=arm
# Base container version
ARG BASE_VERSION=3.0.8
# Application Name
ARG APP_EXECUTABLE=single
# Debug port
ARG SSH_DEBUG_PORT=
# Run as
ARG SSHUSERNAME=
# Board GPU vendor prefix
ARG GPU=-vivante
# BUILD ------------------------------------------------------------------------
FROM --platform=linux/${IMAGE_ARCH} torizon/wayland-base${GPU}:${BASE_VERSION} AS Deploy
ARG IMAGE_ARCH
ARG GPU
ARG SSH_DEBUG_PORT
ARG APP_EXECUTABLE
ARG SSHUSERNAME
ENV APP_EXECUTABLE ${APP_EXECUTABLE}
# SSH for remote debug
EXPOSE ${SSH_DEBUG_PORT}
EXPOSE 9229
# Make sure we don't get notifications we can't answer during building.
ENV DEBIAN_FRONTEND="noninteractive"
# stick to bookworm on /etc/apt/sources.list.d
RUN sed -i 's/sid/bookworm/g' /etc/apt/sources.list.d/debian.sources
# for vivante GPU we need some "special" sauce
RUN apt-get -q -y update && \
if [ "${GPU}" = "-vivante" ]; then \
apt-get -q -y install imx-gpu-viv-wayland-dev \
; else \
apt-get -q -y install libgl1 \
; fi \
apt-get clean && apt-get autoremove && \
rm -rf /var/lib/apt/lists/*
# your regular RUN statements here
# Install required packages
apt-get -q -y install \
openssl \
openssh-server \
rsync \
file \
curl \
libatspi2.0-0 \
libgconf-2-4 \
libglib2.0-bin \
libgtk2.0-0 \
libgtk-3-0 \
libnotify4 \
libnss3 \
libuuid1 \
libxcb-dri3-0 \
xdg-utils \
libxss1 \
libxtst6 \
libasound2 \
smbclient \
ntpdate \
fonts-noto fonts-noto-color-emoji fonts-noto-cjk \
qpdf && \
# CUPS
usbutils ipp-usb cups cups-filters \
printer-driver-cups-pdf \
avahi-utils && \
# printer-driver-all \
# printer-driver-foo2zjs \
# foomatic-db-compressed-ppds \
# automate for torizonPackages.json
# DO NOT REMOVE THIS LABEL: this is used for VS Code automation
# __torizon_packages_dev_start__
# __torizon_packages_dev_end__
# ⚠️ DEBUG PURPOSES ONLY!!
# copies RSA key to enable SSH login for user
COPY .conf/id_rsa.pub /id_rsa.pub
# create folders needed for the different components
# configures SSH access to the container and sets environment by default
RUN mkdir /var/run/sshd && \
sed 's@session\s*required\s*pam_loginuid.so@session optional pam_loginuid.so@g' \
-i /etc/pam.d/sshd && \
if test $SSHUSERNAME != root ; \
then mkdir -p /home/$SSHUSERNAME/.ssh ; \
else mkdir -p /root/.ssh ; fi && \
then cp /id_rsa.pub /home/$SSHUSERNAME/.ssh/authorized_keys ; \
else cp /id_rsa.pub /root/.ssh/authorized_keys ; fi && \
echo "PermitUserEnvironment yes" >> /etc/ssh/sshd_config && \
echo "Port ${SSH_DEBUG_PORT}" >> /etc/ssh/sshd_config && \
su -c "env" $SSHUSERNAME > /etc/environment
RUN rm -r /etc/ssh/ssh*key && \
dpkg-reconfigure openssh-server
RUN echo "torizon:Pa55w0rd" | chpasswd
RUN usermod -aG sudo torizon
RUN usermod -aG lpadmin torizon
CMD [ "/usr/bin/bash", "/usr/src/prodstart.sh" ]
And then on top of that:
ARG base
FROM $base
FROM --platform=linux/arm64 ${base} AS Deploy
# nc required for 'pinging' printers
netcat-traditional && \
# copy the build
COPY host-scripts /home/torizon/app/host-scripts
COPY prodstart.sh /usr/src/prodstart.sh
COPY out/launcher-linux-arm64 /home/torizon/app
WORKDIR /home/torizon/app
Hi @Steve_S,
Apologies for the delayed response.
From what I can see, the issue appears to be related to Electron, which falls more on the application side. Since we’re not experts in Electron, I’d recommend checking our Partner Network, where you can find partners with the right expertise to support you and help move your project forward. You may also find it helpful to search on Electron forums, as they’re a good place to get guidance from developers familiar with similar issues.
Best regards.
