Hi again, thanks for the summary!
I understand that Weston is the officially supported compositor, but my use case specifically involves Sway (wlroots), as I need a minimal and scriptable Wayland environment for a kiosk-style Qt app.
Just to clarify, I’m using a custom Yocto build based on the official Toradex BSP for Colibri iMX8X. Here’s what I’ve verified:
- I do have
/dev/galcore
present.
- Kernel is built with
CONFIG_MXC_GPU_VIV=y
dmesg
shows that the Vivante GPU is initialized:
[drm] Initialized vivante 1.0.0 20170808 for 80000000.imx8_gpu0_ss on minor 2
- I’m using the default Toradex BSP device tree.
- When I run
glmark2-es2-wayland
under Weston, I get a score around 929, confirming that GPU acceleration works under Weston.
- However, when I launch a Qt app under Sway, it falls back to LLVMpipe (software rendering), and I see logs like:
00:00:00.000 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:338] Sway version 1.9-dev-2bba8a86 (Dec 14 2023, branch 'v1.9')
00:00:00.000 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:339] wlroots version 0.17.0
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:120] Linux colibri-imx8x-06858902 6.6.74-7.1.0-devel-g0459206db704 #1 SMP PREEMPT Mon Feb 3 12:55:19 UTC 2025 aarch64 GNU/Linux
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:136] Contents of /etc/os-release:
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:120] ID=horse-wlroots
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:120] NAME="user "
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:120] VERSION="7.1.0-devel-20250115102948+build.0 (scarthgap)"
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:120] VERSION_ID=7.1.0-devel-20250115102948-build.0
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:120] VERSION_CODENAME="scarthgap"
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:120] PRETTY_NAME="user 7.1.0-devel-20250115102948+build.0 (scarthgap)"
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:120] CPE_NAME="cpe:/o:openembedded:horse-wlroots:7.1.0-devel-20250115102948+build.0"
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:108] LD_LIBRARY_PATH=
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:108] LD_PRELOAD=
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:108] PATH=/usr/local/bin:/usr/bin:/bin
00:00:00.007 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:108] SWAYSOCK=
00:00:00.008 [INFO] [/usr/src/debug/sway-1.9/1.9-dev/sway/main.c:376] Starting sway version 1.9-dev-2bba8a86 (Dec 14 2023, branch 'v1.9')
00:00:00.008 [DEBUG] [/usr/src/debug/sway-1.9/1.9-dev/sway/server.c:118] Initializing Wayland server
00:00:00.008 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/backend.c:309] Loading user-specified backends due to WLR_BACKENDS: drm,libinput
00:00:00.008 [INFO] [wlr] [libseat] [c/debug/seatd/0.8.0/libseat/backend/seatd.c:64] Could not connect to socket /run/seatd.sock: No such file or directory
00:00:00.008 [INFO] [wlr] [libseat] [c/debug/seatd/0.8.0/libseat/libseat.c:76] Backend 'seatd' failed to open seat, skipping
00:00:00.021 [INFO] [wlr] [libseat] [c/debug/seatd/0.8.0/libseat/libseat.c:73] Seat opened with backend 'logind'
00:00:00.021 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/session/session.c:109] Successfully loaded libseat session
00:00:00.031 [DEBUG] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/session/session.c:384] Ignoring '/dev/dri/card2': not a KMS device
00:00:00.042 [DEBUG] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/session/session.c:384] Ignoring '/dev/dri/card1': not a KMS device
00:00:00.051 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/backend.c:213] Found 2 GPUs
00:00:00.051 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/backend.c:202] Initializing DRM backend for /dev/dri/card3 (mxsfb-drm)
00:00:00.051 [DEBUG] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/drm.c:110] Using atomic DRM interface
00:00:00.051 [DEBUG] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/drm.c:123] ADDFB2 modifiers supported
00:00:00.051 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/drm.c:255] Found 1 DRM CRTCs
00:00:00.052 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/drm.c:213] Found 1 DRM planes
00:00:00.052 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/backend.c:202] Initializing DRM backend for /dev/dri/card0 (vkms)
00:00:00.052 [DEBUG] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/drm.c:110] Using atomic DRM interface
00:00:00.052 [DEBUG] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/drm.c:123] ADDFB2 modifiers supported
00:00:00.052 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/drm.c:255] Found 1 DRM CRTCs
00:00:00.052 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/drm.c:213] Found 2 DRM planes
00:00:00.052 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/util/env.c:25] Loading WLR_RENDERER option: gles2
00:00:00.052 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/egl.c:206] Supported EGL client extensions: EGL_EXT_client_extensions EGL_EXT_device_base EGL_EXT_device_enumeration EGL_EXT_device_query EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses EGL_KHR_debug EGL_EXT_platform_device EGL_EXT_explicit_device EGL_EXT_platform_wayland EGL_KHR_platform_wayland EGL_EXT_platform_x11 EGL_KHR_platform_x11 EGL_EXT_platform_xcb EGL_MESA_platform_gbm EGL_KHR_platform_gbm EGL_MESA_platform_surfaceless
00:00:00.060 [ERROR] [wlr] [EGL] command: eglQueryDeviceStringEXT, error: EGL_BAD_PARAMETER (0x300c), message: "eglQueryDeviceStringEXT"
00:00:00.060 [DEBUG] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/egl.c:509] DRM device '/dev/dri/card0' has no render node, falling back to primary node
MESA-LOADER: failed to open vkms: /usr/lib/dri/vkms_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/dri, suffix _dri)
00:00:00.122 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/egl.c:320] Software rendering detected, please use the WLR_RENDERER_ALLOW_SOFTWARE environment variable to proceed
00:00:00.122 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/egl.c:572] Failed to initialize EGL context
00:00:00.122 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/gles2/renderer.c:804] Could not initialize EGL
00:00:00.122 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/wlr_renderer.c:346] Failed to create a GLES2 renderer
00:00:00.122 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/wlr_renderer.c:426] Could not initialize renderer
00:00:00.122 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/renderer.c:27] Failed to create renderer
00:00:00.122 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/drm/backend.c:259] Failed to initialize renderer
00:00:00.124 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/backend/backend.c:221] Failed to create DRM backend
00:00:00.124 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/util/env.c:25] Loading WLR_RENDERER option: gles2
00:00:00.124 [INFO] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/egl.c:206] Supported EGL client extensions: EGL_EXT_client_extensions EGL_EXT_device_base EGL_EXT_device_enumeration EGL_EXT_device_query EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses EGL_KHR_debug EGL_EXT_platform_device EGL_EXT_explicit_device EGL_EXT_platform_wayland EGL_KHR_platform_wayland EGL_EXT_platform_x11 EGL_KHR_platform_x11 EGL_EXT_platform_xcb EGL_MESA_platform_gbm EGL_KHR_platform_gbm EGL_MESA_platform_surfaceless
00:00:00.132 [ERROR] [wlr] [EGL] command: eglQueryDeviceStringEXT, error: EGL_BAD_PARAMETER (0x300c), message: "eglQueryDeviceStringEXT"
00:00:00.132 [DEBUG] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/egl.c:509] DRM device '/dev/dri/card3' has no render node, falling back to primary node
00:00:00.194 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/egl.c:320] Software rendering detected, please use the WLR_RENDERER_ALLOW_SOFTWARE environment variable to proceed
00:00:00.194 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/egl.c:572] Failed to initialize EGL context
00:00:00.194 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/gles2/renderer.c:804] Could not initialize EGL
00:00:00.194 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/wlr_renderer.c:346] Failed to create a GLES2 renderer
00:00:00.194 [ERROR] [wlr] [/usr/src/debug/wlroots-0.17/0.17.0/render/wlr_renderer.c:426] Could not initialize renderer
00:00:00.194 [ERROR] [/usr/src/debug/sway-1.9/1.9-dev/sway/server.c:132] Failed to create renderer
and similar EGL/DRI-related messages.
So my key question is:
Is GPU acceleration with Vivante (GC7000Lite) officially supported (or even possible) when using Sway (wlroots) as the Wayland compositor on Colibri iMX8X?
If not officially supported, is there any known workaround? (e.g. patching eglplatform_wayland.so
, tweaking DRI config, or using alternate compositors that are wlroots-based but more compatible?)
I’d appreciate any guidance from the support team or community — I’m comfortable making adjustments in the Yocto build or testing experimental patches if needed.
Thanks!
