In Visual Studio Code when i try to connect to a new device this appears:
[01-16 22:35:00.308] User is not enabled to execute commands as root.
[01-16 22:35:00.309] Error (524) - User root is not enabled to execute commands as root.
Session contents restored from 17/02/2022 at 14:50:36
Serving on http://kubernetes.docker.internal:5000
INFO:root:REST → /api/version
INFO:root:REST ← /api/version - 200
INFO:root:REST → /api/version/docker
INFO:root:REST ← /api/version/docker - 200
INFO:root:REST → /api/devices
INFO:root:REST → /api/setup/enableemulation
INFO:root:REST ← /api/devices - 200
INFO:root:REST ← /api/setup/enableemulation - 200
INFO:root:REST → /api/eulas
INFO:root:REST ← /api/eulas - 200
INFO:root:REST → /api/devices/network_detect
INFO:root:DETECT - Trying to detect device 192.168.1.152.
WARNING:root:DETECT - Login successful.
INFO:root:DETECT - Toradex device id 06900755
INFO:root:DETECT - colibri-imx6ull detected :: Model 0036
ERROR:root:Error: 524 User is not enabled to execute commands as root. User root is not enabled to execute commands as root.
INFO:root:REST ← /api/devices/network_detect - 524
Output:
[01-17 14:50:43.772] Initializing Torizon Extension
[01-17 14:50:43.779] Checking system setup…
[01-17 14:50:48.401] Checking Moses …
[01-17 14:50:48.401] Starting backend local instance running on port 5000
[01-17 14:51:04.415] Torizon Backend version 1.0 API version: 1.0
[01-17 14:51:04.416] Torizon IDE backend started
[01-17 14:51:04.418] Checking Docker …
[01-17 14:51:04.760] Docker version 20.10.12 build 459d0df
[01-17 14:51:05.240] No devices registered
[01-17 14:51:07.192] ARM emulation enabled.
[01-17 14:51:07.214] Torizon: no application loaded.
[01-17 14:51:07.236] LA_OPT_NXP_Software_License v5 January 2019 EULA accepted
[01-17 14:51:33.050] User is not enabled to execute commands as root.
[01-17 14:51:33.050] Error (524) - User root is not enabled to execute commands as root.
