I am trying to use mipi cameras from Vision Components (VK000514) on my Toradex board together with Torizon OS. Looks like OS doesn’t have any drivers by default. Does anybody have experience where to get and how to integrate them?
MIPI Camera Integration with Torizon OS
Based on your hardware setup (Verdin iMX8M Plus on Verdin Development Board with Torizon OS 7.4.0), you’re working with a well-supported platform for camera integration(1).
General Camera Integration Approach
For MIPI cameras that don’t have built-in drivers in Torizon OS, you’ll need to use TorizonCore Builder to create a custom image with the required camera drivers(1)(2). This is the standard approach for integrating third-party camera modules.
Required Steps
Device Tree Overlay Creation: You’ll need to create device tree overlays specific to your Vision Components VK000514 camera(2)
Driver Integration: Use TorizonCore Builder to add the camera driver source code to your custom Torizon OS image(2)
Container Setup: Configure containers for camera usage with proper hardware access(1)
Hardware Access Requirements
When working with cameras in containers, you need specific bind mounts and device access(1):
Since Vision Components cameras require specific drivers not included in standard Torizon OS, I recommend checking with Vision Components directly for:
Device tree overlay examples for their VK000514 camera
Driver source code compatible with kernel 6.6.101
Integration documentation specific to their MIPI camera modules
The integration process follows the same pattern as other third-party cameras like the Framos FSM:GO series documented in our guides(2).
Vision Components usually supplies the needed drivers in a Yocto Layer.
You can find it here: Vision Components MIPI CSI-2 driver for NXP SoMs
Using Yocto would be the most straight-forward way to integrate the driver, as it is the method supplied by the vendor.
However, using TorizonCore Builder may be possible as well, by adding an external module.
Do you know which sensor is used on the VK000514?
I have supported one of your colleagues before with Vision Components cameras, but maybe you are using a different sensor.
