Dear sir,
recorded video is moving vertically with some green line.
i referred your link over there.Analogue Camera Module ver. 2.0A with Apalis IMX6 - Vsync & Capture Artifacts [SOLVED] - Technical Support - Toradex Community .
my problem get solved at that time.[ i2cset -f 3 0x21 244 0x1d b ]
But once i reset/power on again it working with the same problem.how it can be recognized permanently.
Dear sir,
can any one give me the solution for above problem .thanks for support
regards,
ganesh
One possible solution would be to put the command in a script and have the script executed automatically at startup.
Dear sir,
thank you i got it.
