Video Streaming from Apalis tk1 to Apalis imx6q
I am trying to stream web-cam video from tk1 to imx6 using RTP. I found that below pipelines of Gstreame
1. Sender (Apalis tk1)
gst-launch-1.0 -v v4l2src \
! video/x-raw,format=YUY2,width=640,height=480 \
! jpegenc \
! rtpjpegpay \
! udpsink host=127.0.0.1 port=5000
and
2. Receiver (Apalis imx6)
gst-launch-1.0 -v udpsrc port=5000 \
! application/x-rtp, media=video, clock-rate=90000, encoding-name=JPEG, payload=26 \
! rtpjpegdepay \
! jpegdec \
! xvimagesink sync=0
Sender seems okay to convey the video streaming, but in receiver part, it shows
root@apalis-imx6:~#     gst-launch-1.0 -v udpsrc port=5000 \
    >     ! rtpjpegdepay \
    >     ! jpegdec \
    Setting pipeline to PAUSED ...
    ERROR: Pipeline doesn't want to pause.
    ERROR: from element /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Could not initialise Xv output
    Additional debug info:
    ../../../gst-plugins-base-1.12.2/sys/xvimage/xvimagesink.c(1759): gst_xv_image_sink_open (): /GstPipeline:pipeline0/GstXvImageSi:
    Could not open display (null)
    Setting pipeline to NULL ...
    Freeing pipeline ...
I thought I have to use “fbdevsink” instead of “xvimagesink”, because my imx6 OS is Apalis-iMX6_Console-Image. But, still no luck.
I will be so helpful if you could let me know what pipelines do I need to use in receiver (imx6 console)
Thank you in advance.
hi @hkhunkim
Have you done any changes to the Software? Could you update to Bsp 2.8b5 and the newest Jetpack Image on TK1 and check if this works.
After updating bsp 2.8b5 still does not work.. But, I found that
Sender
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=640,height=480,framerate=\(fraction\)30/1 ! videoconvert ! jpegenc ! udpsink host=10.1.10.2 port=5000
Receiver
gst-launch-1.0 -v udpsrc port=5000 ! jpegdec ! videoconvert ! fbdevsink sync=false
This above pipeline might work, but in sender (TK1), it says
gstmultiudpsink.c(607): gst_multiudpsink_render (): /GstPipeline:pipeline0/GstUDPSink:udpsi:
Reason: Error sending message: Network is unreachable
WARNING: from element /GstPipeline:pipeline0/GstUDPSink:udpsink0: Error sending UDP packet
Would you let me know how to set up ethernet network inbetween two boards?
I have been used
[Sender]
ip link set eth1 up (Jectpack does not insmod eth0 I think)
ip addr add 10.1.10.5/24 broadcast 10.1.10.255 dev eth1
ip route add default via 10.1.10.1
[Receiver]
ip link set eth0 up
ip addr add 10.1.10.2/24 broadcast 10.1.10.255 dev eth0
But it doesn’t work.
hi @hkhunkim: We will try to reproduce this issue on our side.
There are just few questions: What is your application? Are you trying to show the stream on Apalis iMX6 on a display or just saving the stream to harddisk.
