We tried to play video in loop, but loop is not working. Help us to resolve the issue.
This our QML code:
Video {
anchors.centerIn: parent
width: 1720
height: 980
source: “qrc:/images/animatedcluster.mp4”
loops: MediaPlayer.Infinite
Component.onCompleted: {
videoPlayer.play()
we are using the capacitive Touch Display 10.1" LVDS.
Version:
root@apalis-imx8-07239822:~# cat /etc/os-release
ID=tdx-xwayland
NAME=“TDX Wayland with XWayland”
VERSION=“6.7.0-devel-20240624041824+build.0 (kirkstone)”
VERSION_ID=6.7.0-devel-20240624041824-build.0
PRETTY_NAME=“TDX Wayland with XWayland 6.7.0-devel-20240624041824+build.0 (kirkstone)”
DISTRO_CODENAME=“kirkstone”
To address the issue of video looping not working on your Apalis iMX8 with the Capacitive Touch Display 10.1" LVDS, let’s go through a few troubleshooting steps and potential solutions:
Check QML Code for Correctness:
Your QML code looks mostly correct, but ensure that the loops
property is set correctly. The MediaPlayer.Infinite
should be a valid constant. If it isn’t, you might need to use a different approach to loop the video.
Verify MediaPlayer Support:
Ensure that the MediaPlayer
component supports the loops
property. If it doesn’t, you might need to manually handle the looping by listening to the onStopped
signal and restarting the video.
Manual Looping:
If the loops
property is not working as expected, you can manually loop the video by connecting to the onStopped
signal. Here is an example of how you can modify your QML code:
Video {
width: 1720
height: 980
source: "qrc:/images/animatedcluster.mp4"
onStopped: {
videoPlayer.play()
videoPlayer.play()
Check for Software Updates:
Ensure that your software stack is up to date. Sometimes, issues like these are resolved in newer versions of the software. You are using TDX Wayland with XWayland 6.7.0-devel-20240624041824+build.0 (kirkstone)
. Check if there are any updates or patches available for your version.
Consult Documentation and Support:
If the issue persists, consult the documentation for the Video
and MediaPlayer
components to ensure there are no known issues or additional properties that need to be set. Additionally, you can reach out to Toradex technical support for further assistance.
If none of these steps resolve the issue, it might be a specific problem with the software stack or the way the video playback is handled on the Apalis iMX8. In that case, providing detailed logs and reaching out to technical support would be the next best step.
we tried this, still not working
onStopped: {
videoPlayer.play()
Hi @Shanmugapriyan,
Have you already taken reference from QML video example from QT?
Unfortunately, this is related to application support and we would not be able to provide you much help on this.
