spi-fsl-dspi driver does not supports DMA.
I made some driver modification for DMA support.
After code test I got next result. DMA transmit is ok. DMA receives about 50% of lost packets (some parts of buffer contents previous message). The issue is in DMA. Not all data are copied from device fifo into memory. RXCTR = 0 in rx callback transaction indicates that data is read. SPIx_RXFRn register shows a new correct value.
Do you have idea about reason of bad DMA transfers?
Code is below.
* drivers/spi/spi-fsl-dspi.c
* Copyright 2013 Freescale Semiconductor, Inc.
* Freescale DSPI driver
* This file contains a driver for the Freescale DSPI
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
#include <linux/clk.h>
#include <linux/delay.h>
#include <linux/err.h>
#include <linux/errno.h>
#include <linux/interrupt.h>
#include <linux/io.h>
#include <linux/kernel.h>
#include <linux/math64.h>
#include <linux/module.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <linux/pinctrl/consumer.h>
#include <linux/platform_device.h>
#include <linux/pm_runtime.h>
#include <linux/regmap.h>
#include <linux/sched.h>
#include <linux/spi/spi.h>
#include <linux/dmaengine.h>
#include <linux/dma-mapping.h>
#include <linux/spi/spi_bitbang.h>
#include <linux/time.h>
#include <linux/mutex.h>
#define DRIVER_NAME "fsl-dspi"
#define DMA
#define TRAN_STATE_RX_VOID 0x01
#define TRAN_STATE_TX_VOID 0x02
#define TRAN_STATE_WORD_ODD_NUM 0x04
#define DSPI_FIFO_SIZE 4
#define SPI_MCR 0x00
#define SPI_MCR_MASTER (1 << 31)
#define SPI_MCR_PCSIS (0x3F << 16)
#define SPI_MCR_CLR_TXF (1 << 11)
#define SPI_MCR_CLR_RXF (1 << 10)
#define SPI_TCR 0x08
#define SPI_CTAR(x) (0x0c + (((x) & 0x3) * 4))
#define SPI_CTAR_FMSZ(x) (((x) & 0x0000000f) << 27)
#define SPI_CTAR_CPOL(x) ((x) << 26)
#define SPI_CTAR_CPHA(x) ((x) << 25)
#define SPI_CTAR_LSBFE(x) ((x) << 24)
#define SPI_CTAR_PCSSCK(x) (((x) & 0x00000003) << 22)
#define SPI_CTAR_PASC(x) (((x) & 0x00000003) << 20)
#define SPI_CTAR_PDT(x) (((x) & 0x00000003) << 18)
#define SPI_CTAR_PBR(x) (((x) & 0x00000003) << 16)
#define SPI_CTAR_CSSCK(x) (((x) & 0x0000000f) << 12)
#define SPI_CTAR_ASC(x) (((x) & 0x0000000f) << 8)
#define SPI_CTAR_DT(x) (((x) & 0x0000000f) << 4)
#define SPI_CTAR_BR(x) ((x) & 0x0000000f)
#define SPI_CTAR_SCALE_BITS 0xf
#define SPI_CTAR0_SLAVE 0x0c
#define SPI_SR 0x2c
#define SPI_SR_EOQF 0x10000000
#define SPI_RSER_TFFFE 0x02000000
#define SPI_RSER_TFFFD 0x01000000
#define SPI_RSER_RFDFE 0x00020000
#define SPI_RSER_RFDFD 0x00010000
#define SPI_RSER 0x30
#define SPI_RSER_EOQFE 0x10000000
#define SPI_PUSHR 0x34
#define SPI_PUSHR_CONT (1 << 31)
#define SPI_PUSHR_CTAS(x) (((x) & 0x00000003) << 28)
#define SPI_PUSHR_EOQ (1 << 27)
#define SPI_PUSHR_CTCNT (1 << 26)
#define SPI_PUSHR_PCS(x) (((1 << x) & 0x0000003f) << 16)
#define SPI_PUSHR_TXDATA(x) ((x) & 0x0000ffff)
#define SPI_PUSHR_SLAVE 0x34
#define SPI_POPR 0x38
#define SPI_POPR_RXDATA(x) ((x) & 0x0000ffff)
#define SPI_TXFR0 0x3c
#define SPI_TXFR1 0x40
#define SPI_TXFR2 0x44
#define SPI_TXFR3 0x48
#define SPI_RXFR0 0x7c
#define SPI_RXFR1 0x80
#define SPI_RXFR2 0x84
#define SPI_RXFR3 0x88
#define SPI_FRAME_BITS(bits) SPI_CTAR_FMSZ((bits) - 1)
#define SPI_FRAME_BITS_MASK SPI_CTAR_FMSZ(0xf)
#define SPI_FRAME_BITS_16 SPI_CTAR_FMSZ(0xf)
#define SPI_FRAME_BITS_8 SPI_CTAR_FMSZ(0x7)
#define SPI_CS_INIT 0x01
#define SPI_CS_ASSERT 0x02
#define SPI_CS_DROP 0x04
#define DSPI_DMA_BUFSIZE 4096
struct mutex mlock;
struct chip_data {
u32 mcr_val;
u32 ctar_val;
u16 void_write_data;
struct fsl_dspi {
struct spi_master *master;
struct platform_device *pdev;
struct regmap *regmap;
int irq;
struct clk *clk;
struct spi_transfer *cur_transfer;
struct spi_message *cur_msg;
struct chip_data *cur_chip;
size_t len;
void *tx;
void *tx_end;
void *rx;
void *rx_end;
char dataflags;
u8 cs;
u32 cs_change;
wait_queue_head_t waitq;
u32 waitflags;
struct fsl_dspi_dma *dma;
/*For DMA Support*/
struct fsl_dspi_dma {
struct dma_chan *chan_tx;
struct dma_chan *chan_rx;
u32 *dma_tx_buf;
u32 *dma_rx_buf; //*u16
dma_addr_t phybase;
dma_addr_t tx_mem_addr;
dma_addr_t rx_mem_addr;
struct completion cmd_tx_complete;
struct completion cmd_rx_complete;
struct dma_async_tx_descriptor *tx_desc;
struct dma_async_tx_descriptor *rx_desc;
static int dspi_tx_dma(struct fsl_dspi *dspi);
static inline int is_double_byte_mode(struct fsl_dspi *dspi)
unsigned int val;
regmap_read(dspi->regmap, SPI_CTAR(0), &val);
return ((val & SPI_FRAME_BITS_MASK) == SPI_FRAME_BITS(8)) ? 0 : 1;
static void hz_to_spi_baud(char *pbr, char *br, int speed_hz,
unsigned long clkrate)
/* Valid baud rate pre-scaler values */
int pbr_tbl[4] = {2, 3, 5, 7};
int brs[16] = { 2, 4, 6, 8,
16, 32, 64, 128,
256, 512, 1024, 2048,
4096, 8192, 16384, 32768 };
int scale_needed, scale, minscale = INT_MAX;
int i, j;
scale_needed = clkrate / speed_hz;
if (clkrate % speed_hz)
scale_needed++;
for (i = 0; i < ARRAY_SIZE(brs); i++)
for (j = 0; j < ARRAY_SIZE(pbr_tbl); j++) {
scale = brs[i] * pbr_tbl[j];
if (scale >= scale_needed) {
if (scale < minscale) {
minscale = scale;
*br = i;
*pbr = j;
break;
if (minscale == INT_MAX) {
pr_warn("Can not find valid baud rate,speed_hz is %d,clkrate is %ld, we use the max prescaler value.\n",
speed_hz, clkrate);
*pbr = ARRAY_SIZE(pbr_tbl) - 1;
*br = ARRAY_SIZE(brs) - 1;
static void ns_delay_scale(char *psc, char *sc, int delay_ns,
int pscale_tbl[4] = {1, 3, 5, 7};
int i, j;
u32 remainder;
scale_needed = div_u64_rem((u64)delay_ns * clkrate, NSEC_PER_SEC,
&remainder);
if (remainder)
scale_needed++;
for (i = 0; i < ARRAY_SIZE(pscale_tbl); i++)
for (j = 0; j <= SPI_CTAR_SCALE_BITS; j++) {
scale = pscale_tbl[i] * (2 << j);
minscale = scale;
*psc = i;
*sc = j;
break;
pr_warn("Cannot find correct scale values for %dns delay at clkrate %ld, using max prescaler value",
delay_ns, clkrate);
*psc = ARRAY_SIZE(pscale_tbl) - 1;
*sc = SPI_CTAR_SCALE_BITS;
static int dspi_transfer_write(struct fsl_dspi *dspi)
int tx_count = 0;
int tx_word;
u16 d16;
u8 d8;
u32 dspi_pushr = 0;
int first = 1;
tx_word = is_double_byte_mode(dspi);
/* If we are in word mode, but only have a single byte to transfer
* then switch to byte mode temporarily. Will switch back at the
* end of the transfer.
if (tx_word && (dspi->len == 1)) {
dspi->dataflags |= TRAN_STATE_WORD_ODD_NUM;
regmap_update_bits(dspi->regmap, SPI_CTAR(0),
SPI_FRAME_BITS_MASK, SPI_FRAME_BITS(8));
tx_word = 0;
while (dspi->len && (tx_count < DSPI_FIFO_SIZE)) {
if (tx_word) {
if (dspi->len == 1)
break;
if (!(dspi->dataflags & TRAN_STATE_TX_VOID)) {
d16 = *(u16 *)dspi->tx;
dspi->tx += 2;
} else {
d16 = dspi->void_write_data;
dspi_pushr = SPI_PUSHR_TXDATA(d16) |
SPI_PUSHR_PCS(dspi->cs) |
SPI_PUSHR_CTAS(0) |
SPI_PUSHR_CONT;
dspi->len -= 2;
} else {
d8 = *(u8 *)dspi->tx;
dspi->tx++;
} else {
d8 = (u8)dspi->void_write_data;
dspi_pushr = SPI_PUSHR_TXDATA(d8) |
SPI_PUSHR_CTAS(0) |
SPI_PUSHR_CONT;
dspi->len--;
if (dspi->len == 0 || tx_count == DSPI_FIFO_SIZE - 1) {
/* last transfer in the transfer */
dspi_pushr |= SPI_PUSHR_EOQ;
if ((dspi->cs_change) && (!dspi->len))
dspi_pushr &= ~SPI_PUSHR_CONT;
} else if (tx_word && (dspi->len == 1))
if (first) {
first = 0;
dspi_pushr |= SPI_PUSHR_CTCNT; /* clear counter */
regmap_write(dspi->regmap, SPI_PUSHR, dspi_pushr);
tx_count++;
return tx_count * (tx_word + 1);
static int dspi_transfer_read(struct fsl_dspi *dspi)
int rx_count = 0;
int rx_word = is_double_byte_mode(dspi);
u16 d;
while ((dspi->rx < dspi->rx_end)
&& (rx_count < DSPI_FIFO_SIZE)) {
if (rx_word) {
unsigned int val;
if ((dspi->rx_end - dspi->rx) == 1)
break;
regmap_read(dspi->regmap, SPI_POPR, &val);
d = SPI_POPR_RXDATA(val);
if (!(dspi->dataflags & TRAN_STATE_RX_VOID))
*(u16 *)dspi->rx = d;
dspi->rx += 2;
} else {
unsigned int val;
*(u8 *)dspi->rx = d;
dspi->rx++;
rx_count++;
return rx_count;
static int dspi_transfer_one_message(struct spi_master *master,
struct spi_message *message)
struct fsl_dspi *dspi = spi_master_get_devdata(master);
struct spi_device *spi = message->spi;
struct spi_transfer *transfer;
int status = 0;
int i = 0;
u16 * val = 0;
message->actual_length = 0;
list_for_each_entry(transfer, &message->transfers, transfer_list) {
dspi->cur_transfer = transfer;
dspi->cur_msg = message;
dspi->cur_chip = spi_get_ctldata(spi);
dspi->cs = spi->chip_select;
if (dspi->cur_transfer->transfer_list.next
== &dspi->cur_msg->transfers)
transfer->cs_change = 1;
dspi->cs_change = transfer->cs_change;
dspi->void_write_data = dspi->cur_chip->void_write_data;
dspi->dataflags = 0;
dspi->tx = (void *)transfer->tx_buf;
dspi->tx_end = dspi->tx + transfer->len;
dspi->rx = transfer->rx_buf;
dspi->rx_end = dspi->rx + transfer->len;
dspi->len = transfer->len;
#ifdef DMA
// regmap_write(dspi->regmap, SPI_RSER,SPI_RSER_TFFFE | SPI_RSER_TFFFD
// | SPI_RSER_RFDFE | SPI_RSER_RFDFD);
#endif
if (!dspi->rx)
dspi->dataflags |= TRAN_STATE_RX_VOID;
if (!dspi->tx)
dspi->dataflags |= TRAN_STATE_TX_VOID;
regmap_write(dspi->regmap, SPI_MCR, dspi->cur_chip->mcr_val);
regmap_update_bits(dspi->regmap, SPI_MCR,
SPI_MCR_CLR_TXF | SPI_MCR_CLR_RXF,
SPI_MCR_CLR_TXF | SPI_MCR_CLR_RXF);
regmap_write(dspi->regmap, SPI_CTAR(0),
dspi->cur_chip->ctar_val);
if (transfer->speed_hz)
#ifdef DMA
if(transfer->tx_buf == NULL) //if tx_buff == NULL then send dummy
for(i=0;i<dspi->len/2-1;i++)
dspi->dma->dma_tx_buf[i]=SPI_PUSHR_PCS(0)|SPI_PUSHR_CONT;
dspi->dma->dma_tx_buf[dspi->len-1]=SPI_PUSHR_PCS(0);
}else{
val = (u16 *)transfer->tx_buf;
for(i=0;i<(dspi->len/2-1);i++)
dspi->dma->dma_tx_buf[i] = (u32)val[i]|SPI_PUSHR_CONT|SPI_PUSHR_PCS(0);
dspi->dma->dma_tx_buf[i] = (u32)val[i]|SPI_PUSHR_PCS(0);
dev_info(&dspi->pdev->dev, "From SAIT driver %u", dspi->len);
for(i=0;i<3;i++)
dma->dma_tx_buf[i]=i|SPI_PUSHR_PCS(0)|SPI_PUSHR_CONT;
dma->dma_tx_buf[3]=SPI_PUSHR_PCS(0)|3;
message->actual_length = DSPI_DMA_BUFSIZE;
dspi_tx_dma(dspi);
#else
regmap_write(dspi->regmap, SPI_RSER, SPI_RSER_EOQFE);
message->actual_length += dspi_transfer_write(dspi);
if (wait_event_interruptible(dspi->waitq, dspi->waitflags))
dev_err(&dspi->pdev->dev, "wait transfer complete fail!\n");
dspi->waitflags = 0;
if (transfer->delay_usecs)
udelay(transfer->delay_usecs);
#endif
message->status = status;
//mutex_lock (&mlock);
spi_finalize_current_message(master);
//mutex_unlock (&mlock);
return status;
static int dspi_setup(struct spi_device *spi)
struct chip_data *chip;
struct fsl_dspi *dspi = spi_master_get_devdata(spi->master);
u32 cs_sck_delay = 0, sck_cs_delay = 0;
unsigned char br = 0, pbr = 0, pcssck = 0, cssck = 0;
unsigned char pasc = 0, asc = 0, fmsz = 0;
unsigned long clkrate;
if ((spi->bits_per_word >= 4) && (spi->bits_per_word <= 16)) {
fmsz = spi->bits_per_word - 1;
} else {
pr_err("Invalid wordsize\n");
return -ENODEV;
/* Only alloc on first setup */
if (chip == NULL) {
chip = kzalloc(sizeof(struct chip_data), GFP_KERNEL);
if (!chip)
return -ENOMEM;
of_property_read_u32(spi->dev.of_node, "fsl,spi-cs-sck-delay",
&cs_sck_delay);
of_property_read_u32(spi->dev.of_node, "fsl,spi-sck-cs-delay",
&sck_cs_delay);
chip->mcr_val = SPI_MCR_MASTER | SPI_MCR_PCSIS |
SPI_MCR_CLR_TXF | SPI_MCR_CLR_RXF;
chip->void_write_data = 0;
clkrate = clk_get_rate(dspi->clk);
//spi->max_speed_hz = 8000000; //SRK
hz_to_spi_baud(&pbr, &br, spi->max_speed_hz, clkrate);
/* Set PCS to SCK delay scale values */
ns_delay_scale(&pcssck, &cssck, cs_sck_delay, clkrate);
/* Set After SCK delay scale values */
ns_delay_scale(&pasc, &asc, sck_cs_delay, clkrate);
//SRK changes, for 3.0Mhz
cssck = 0x3;
asc = 0x3;
chip->ctar_val = SPI_CTAR_FMSZ(fmsz)
| SPI_CTAR_CPOL(spi->mode & SPI_CPOL ? 1 : 0)
| SPI_CTAR_CPHA(spi->mode & SPI_CPHA ? 1 : 0)
| SPI_CTAR_LSBFE(spi->mode & SPI_LSB_FIRST ? 1 : 0)
| SPI_CTAR_PCSSCK(pcssck)
| SPI_CTAR_CSSCK(cssck)
| SPI_CTAR_PASC(pasc)
| SPI_CTAR_ASC(asc)
| SPI_CTAR_PBR(pbr)
| SPI_CTAR_BR(br);
spi_set_ctldata(spi, chip);
return 0;
static void dspi_cleanup(struct spi_device *spi)
struct chip_data *chip = spi_get_ctldata((struct spi_device *)spi);
dev_dbg(&spi->dev, "spi_device %u.%u cleanup\n",
spi->master->bus_num, spi->chip_select);
kfree(chip);
static irqreturn_t dspi_interrupt(int irq, void *dev_id)
struct fsl_dspi *dspi = (struct fsl_dspi *)dev_id;
struct spi_message *msg = dspi->cur_msg;
regmap_write(dspi->regmap, SPI_SR, SPI_SR_EOQF);
dspi_transfer_read(dspi);
if (!dspi->len) {
if (dspi->dataflags & TRAN_STATE_WORD_ODD_NUM)
SPI_FRAME_BITS_MASK, SPI_FRAME_BITS(16));
dspi->waitflags = 1;
wake_up_interruptible(&dspi->waitq);
} else
msg->actual_length += dspi_transfer_write(dspi);
return IRQ_HANDLED;
static const struct of_device_id fsl_dspi_dt_ids[] = {
{ .compatible = "fsl,vf610-dspi", .data = NULL, },
{ /* sentinel */ }
MODULE_DEVICE_TABLE(of, fsl_dspi_dt_ids);
#ifdef CONFIG_PM_SLEEP
static int dspi_suspend(struct device *dev)
struct spi_master *master = dev_get_drvdata(dev);
spi_master_suspend(master);
clk_disable_unprepare(dspi->clk);
pinctrl_pm_select_sleep_state(dev);
return 0;
static int dspi_resume(struct device *dev)
pinctrl_pm_select_default_state(dev);
clk_prepare_enable(dspi->clk);
spi_master_resume(master);
return 0;
#endif /* CONFIG_PM_SLEEP */
static SIMPLE_DEV_PM_OPS(dspi_pm, dspi_suspend, dspi_resume);
static const struct regmap_config dspi_regmap_config = {
.reg_bits = 32,
.val_bits = 32,
.reg_stride = 4,
.max_register = 0x88,
#ifdef DMA
static void dspi_tx_dma_callback(void *arg)
struct fsl_dspi *dspi = (struct fsl_dspi *)arg;
struct fsl_dspi_dma *dma = dspi->dma;
dev_info(&dspi->pdev->dev, "tx callback");
/* dma_unmap_single(dma->chan_tx->device->dev, dma->tx_mem_addr,
dspi->len*2, DMA_MEM_TO_DEV);*/
dma_sync_single_for_cpu(dma->chan_tx->device->dev, dma->tx_mem_addr,
complete(&dma->cmd_tx_complete);
static void dspi_rx_dma_callback(void *arg)
u16 * val;
int i;
dma_sync_single_for_cpu(dma->chan_rx->device->dev, dma->rx_mem_addr,
if(dspi->rx != NULL) //if rx_buff != NULL then rx data copy
val = (u16 *)dspi->rx;
for(i=0;i<(dspi->len/2);i++)
dev_info(&dspi->pdev->dev, "rx data %X ",dspi->dma->dma_rx_buf[i]);
val[i] = dspi->dma->dma_rx_buf[i];
dev_info(&dspi->pdev->dev, "rx callback");
complete(&dma->cmd_rx_complete);
struct device *dev = &dspi->pdev->dev;
dma->tx_desc = dmaengine_prep_slave_single(dma->chan_tx, dma->tx_mem_addr,
dspi->len*2, DMA_MEM_TO_DEV,
DMA_PREP_INTERRUPT | DMA_CTRL_ACK);
if (!dma->tx_desc) {
dev_err(dev, "Not able to get desc for DMA xfer\n");
return 0;
dma->tx_desc->callback = dspi_tx_dma_callback;
dma->tx_desc->callback_param = dspi;
if (dma_submit_error(dmaengine_submit(dma->tx_desc))) {
dev_err(dev, "DMA submit failed\n");
return 0;
dma->rx_desc = dmaengine_prep_slave_single(dma->chan_rx, dma->rx_mem_addr,
if (!dma->rx_desc) {
return 0;
dma->rx_desc->callback = dspi_rx_dma_callback;
dma->rx_desc->callback_param = dspi;
if (dma_submit_error(dmaengine_submit(dma->rx_desc))) {
return 0;
reinit_completion(&dspi->dma->cmd_rx_complete);
reinit_completion(&dspi->dma->cmd_tx_complete);
dma_sync_single_for_device(dma->chan_rx->device->dev, dma->dma_rx_buf, dspi->len*2, DMA_MEM_TO_DEV);
dma_sync_single_for_device(dma->chan_tx->device->dev, dma->dma_tx_buf, dspi->len*2, DMA_MEM_TO_DEV);
dma_async_issue_pending(dma->chan_rx);
dev_info(dev, "async_rx");
dma_async_issue_pending(dma->chan_tx);
dev_info(dev, "async_tx");
if(!wait_for_completion_timeout(&dspi->dma->cmd_tx_complete, msecs_to_jiffies(3000))){
dev_err(dev, "DMA TX Timeout\n");
wait_for_completion_timeout(&dspi->dma->cmd_rx_complete, msecs_to_jiffies(3000));
dev_info(dev, "wait for complition end");
return 0;
/* Functions for DMA support */
static int dspi_request_dma(struct fsl_dspi *dspi, dma_addr_t phy_addr)
struct dma_slave_config cfg;
int ret = -EINVAL;
dma = devm_kzalloc(dev, sizeof(*dma), GFP_KERNEL);
dma->phybase = phy_addr;
if (!dma)
return 0;
dma->dma_tx_buf = devm_kzalloc(dev,DSPI_DMA_BUFSIZE, GFP_DMA);
dma->dma_rx_buf = devm_kzalloc(dev,DSPI_DMA_BUFSIZE, GFP_DMA);
dma->chan_rx = dma_request_slave_channel(dev, "rx");
if (dma->chan_rx) {
cfg.direction = DMA_DEV_TO_MEM;
cfg.dst_addr = 0;
cfg.src_addr = dma->phybase + SPI_POPR;
cfg.src_addr_width = DMA_SLAVE_BUSWIDTH_4_BYTES;
cfg.src_maxburst = 1;
ret = dmaengine_slave_config(dma->chan_rx, &cfg);
if (!ret)
dev_info(dev, "Configed DSPI rx channel");
else
return ret;
dma->chan_tx = dma_request_slave_channel(dev, "tx");
if (dma->chan_tx) {
cfg.direction = DMA_MEM_TO_DEV;
cfg.dst_addr = dma->phybase + SPI_PUSHR;
cfg.src_addr = 0;
cfg.dst_addr_width = DMA_SLAVE_BUSWIDTH_4_BYTES;
cfg.dst_maxburst = 1;
ret = dmaengine_slave_config(dma->chan_tx, &cfg);
if (!ret)
dev_info(dev, "Configed DSPI tx channel");
else
return ret;
dspi->dma = dma;
init_completion(&dma->cmd_tx_complete);
init_completion(&dma->cmd_rx_complete);
dev_info(dev, "using %s (tx) and %s (rx) for DMA transfers\n",
dma_chan_name(dma->chan_tx), dma_chan_name(dma->chan_rx));
//----------TX-----------
dma->tx_mem_addr = dma_map_single(dma->chan_tx->device->dev, dma->dma_tx_buf, DSPI_DMA_BUFSIZE, DMA_MEM_TO_DEV);
dev_info(dev, "dspi_tx_dma");
if (dma_mapping_error(dma->chan_tx->device->dev, dma->tx_mem_addr)) {
dev_info(dev, "dma_mapping_error");
//---------------RX----------------
dma->rx_mem_addr = dma_map_single(dma->chan_rx->device->dev, dma->dma_rx_buf, DSPI_DMA_BUFSIZE, DMA_MEM_TO_DEV);
dev_info(dev, "dspi_rx_dma");
if (dma_mapping_error(dma->chan_rx->device->dev, dma->rx_mem_addr)) {
return ret;
static void dspi_release_dma(struct fsl_dspi *dspi)
dma = dspi->dma;
if (dma->chan_tx)
dma_release_channel(dma->chan_tx);
if (dma->chan_rx)
dma_release_channel(dma->chan_rx);
if (dspi->dma)
devm_kfree(&dspi->pdev->dev, dspi->dma);
#endif
static int dspi_probe(struct platform_device *pdev)
struct device_node *np = pdev->dev.of_node;
struct fsl_dspi *dspi;
struct resource *res;
void __iomem *base;
int ret = 0, cs_num, bus_num;
dma_addr_t phy_addr;
mutex_init(&mlock);
master = spi_alloc_master(&pdev->dev, sizeof(struct fsl_dspi));
if (!master)
return -ENOMEM;
dspi->pdev = pdev;
dspi->master = master;
master->transfer = NULL;
master->setup = dspi_setup;
master->transfer_one_message = dspi_transfer_one_message;
master->dev.of_node = pdev->dev.of_node;
master->cleanup = dspi_cleanup;
master->mode_bits = SPI_CPOL | SPI_CPHA;
master->bits_per_word_mask = SPI_BPW_MASK(4) | SPI_BPW_MASK(8) |
SPI_BPW_MASK(16);
ret = of_property_read_u32(np, "spi-num-chipselects", &cs_num);
if (ret < 0) {
dev_err(&pdev->dev, "can't get spi-num-chipselects\n");
goto out_master_put;
master->num_chipselect = cs_num;
ret = of_property_read_u32(np, "bus-num", &bus_num);
if (ret < 0) {
dev_err(&pdev->dev, "can't get bus-num\n");
master->bus_num = bus_num;
res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
base = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(base)) {
ret = PTR_ERR(base);
dspi->regmap = devm_regmap_init_mmio_clk(&pdev->dev, "dspi", base,
&dspi_regmap_config);
if (IS_ERR(dspi->regmap)) {
dev_err(&pdev->dev, "failed to init regmap: %ld\n",
PTR_ERR(dspi->regmap));
return PTR_ERR(dspi->regmap);
dspi->irq = platform_get_irq(pdev, 0);
if (dspi->irq < 0) {
dev_err(&pdev->dev, "can't get platform irq\n");
ret = dspi->irq;
ret = devm_request_irq(&pdev->dev, dspi->irq, dspi_interrupt, 0,
pdev->name, dspi);
if (ret < 0) {
dev_err(&pdev->dev, "Unable to attach DSPI interrupt\n");
dspi->clk = devm_clk_get(&pdev->dev, "dspi");
if (IS_ERR(dspi->clk)) {
ret = PTR_ERR(dspi->clk);
dev_err(&pdev->dev, "unable to get clock\n");
#ifdef DMA
/*Init DMA config if supported*/
phy_addr = (dma_addr_t)res->start;
dev_err(&pdev->dev, "phy_addr= %X \n",phy_addr);
if (dspi_request_dma(dspi,phy_addr)) {
dev_err(&pdev->dev, "request dma channel fail\n");
dspi_release_dma(dspi);
#endif
init_waitqueue_head(&dspi->waitq);
platform_set_drvdata(pdev, master);
ret = spi_register_master(master);
if (ret != 0) {
dev_err(&pdev->dev, "Problem registering DSPI master\n");
goto out_clk_put;
return ret;
out_clk_put:
out_master_put:
spi_master_put(master);
return ret;
static int dspi_remove(struct platform_device *pdev)
struct spi_master *master = platform_get_drvdata(pdev);
/* Disconnect from the SPI framework */
spi_unregister_master(dspi->master);
spi_master_put(dspi->master);
return 0;
static struct platform_driver fsl_dspi_driver = {
.driver.name = DRIVER_NAME,
.driver.of_match_table = fsl_dspi_dt_ids,
.driver.owner = THIS_MODULE,
.driver.pm = &dspi_pm,
.probe = dspi_probe,
.remove = dspi_remove,
module_platform_driver(fsl_dspi_driver);
MODULE_DESCRIPTION("Freescale DSPI Controller Driver");
MODULE_LICENSE("GPL");
MODULE_ALIAS("platform:" DRIVER_NAME);
