I am attempting to use pin PTB19 as GPIO 41 on my VF61 module. I started with a copy of the Toradex device tree file vf610-colibri-eval-v3.dts, named it vf610-colibri-eval-v3test.dts, and changed it by adding the following to the end of the file:
&iomuxc {
vf610-colibri {
pinctrl_hog_0: hoggrp-0 {
fsl,pins = <
VF610_PAD_PTA12__GPIO_5 0x22ed
VF610_PAD_PTA17__GPIO_7 0x22ed
VF610_PAD_PTA20__GPIO_10 0x22ed
VF610_PAD_PTA21__GPIO_11 0x22ed
VF610_PAD_PTA30__GPIO_20 0x22ed
VF610_PAD_PTA31__GPIO_21 0x22ed
VF610_PAD_PTB6__GPIO_28 0x22ed
VF610_PAD_PTB7__GPIO_29 0x22ed
VF610_PAD_PTB16__GPIO_38 0x22ed
VF610_PAD_PTB17__GPIO_39 0x22ed
VF610_PAD_PTB18__GPIO_40 0x22ed
VF610_PAD_PTB19__GPIO_41 0x22ed /* added new gpio */
VF610_PAD_PTB21__GPIO_43 0x22ed
VF610_PAD_PTB22__GPIO_44 0x22ed
VF610_PAD_PTC1__GPIO_46 0x22ed
VF610_PAD_PTC2__GPIO_47 0x22ed
VF610_PAD_PTC3__GPIO_48 0x22ed
VF610_PAD_PTC4__GPIO_49 0x22ed
VF610_PAD_PTC5__GPIO_50 0x22ed
VF610_PAD_PTC6__GPIO_51 0x22ed
VF610_PAD_PTC7__GPIO_52 0x22ed
VF610_PAD_PTC8__GPIO_53 0x22ed
VF610_PAD_PTD30__GPIO_64 0x22ed
VF610_PAD_PTD29__GPIO_65 0x22ed
VF610_PAD_PTD28__GPIO_66 0x22ed
VF610_PAD_PTD26__GPIO_68 0x22ed
VF610_PAD_PTD25__GPIO_69 0x22ed
VF610_PAD_PTD24__GPIO_70 0x22ed
VF610_PAD_PTD9__GPIO_88 0x22ed
VF610_PAD_PTD10__GPIO_89 0x22ed
VF610_PAD_PTD11__GPIO_90 0x22ed
VF610_PAD_PTD12__GPIO_91 0x22ed
VF610_PAD_PTD13__GPIO_92 0x22ed
VF610_PAD_PTB26__GPIO_96 0x22ed
VF610_PAD_PTB28__GPIO_98 0x22ed
VF610_PAD_PTC30__GPIO_103 0x22ed
VF610_PAD_PTA7__GPIO_134 0x22ed
Exactly one line was added to the fsl,pins property. Now when I attempt to boot linux I get the following error on the console:
[ 3.965400] vf610-pinctrl 40048000.iomuxc: pin VF610_PAD_PTB19 already requested by 40048000.iomuxc; cannot claim for gpio-keys
[ 3.993998] vf610-pinctrl 40048000.iomuxc: pin-41 (gpio-keys) status -22
[ 4.009606] vf610-pinctrl 40048000.iomuxc: could not request pin 41 (VF610_PAD_PTB19) from group gpiokeys on device 40048000.iomuxc
[ 4.039532] gpio-keys gpio-keys: Error applying setting, reverse things back
[ 4.056914] input: gpio-keys as /devices/platform/gpio-keys/input/input1
This is apparently because PTB19 is already assigned to pinctrl_gpiokeys in vf-colibri-eval-v3.dtsi. I think this has something to do with some kind of wakeup function, which I do not need.
I have tried to eliminate this pin conflict by using a /delete-node/ line in my modified device tree file to delete the gpio-keys node defiled in vf-colibri-eval-v3.dtsi, but apparently I am not doing it right. My device tree file compiles, but the pin conflict error remains. I want to use a /delete-node/ in my own file because I don’t want to modify any of the toradex device tree include files. How do I properly delete the gpio-keys node?
