Today, AS driver instalation is started each time when a new Colibri VF61 is connected to PC. On PXA320, driver is installed once time and new modules are not required driver installation. How do that VF61 drivers installation has same behaviour like a PXA320?
This happening also on Win 10.
This happening with new Colibri from manufacturer, before device flashing/erasing, registry update and other customization.
I tried using the same EVB as you are using and I still can’t get it to reload the driver. Do you also force Colibri to lower USB speed? You need to add registry
HKLM\Drivers\Builtin\USBOTG\UFN you need to add DWORD value “highspeed” and set it to 1.
I am looking into this but I am not able to reproduce it with 1 module. I see you are using old EVB. Do you force speed of USB in registry? Or did you patch the EVB?
