I have a message error below:
IPv6: eth0: IPv6 duplicate address xxxxxxxxxxxxxxxxx detected!
Perhaps I have several VF50 in the same network. Need I disable the IPv6? And how can I disable the IPv6?
linux version: Colibri-VF_Console-Image 2.8b6.184 20190401
Hello @yunfeng ,
You can refer to out documentation for BSP 2.8
Since we use conmanctl you can try with
config name_of_the_connection --ipv6 off
Best regards
Josep
Hello Josep,
Thank you. Can you give me some more details?
I don’t know where is " config name_of_the_connection --ipv6 off" .
I have below information. Which line that I need to change to “off”
root@GATEWAY:/# connmanctl services
*AO Wired ethernet_00142d000000_cable
root@GATEWAY:/# connmanctl services ethernet_00142d000000_cable
/net/connman/service/ethernet_00142d000000_cable
Type = ethernet
Security = [ ]
State = online
Favorite = True
Immutable = False
AutoConnect = True
Name = Wired
Ethernet = [ Method=auto, Interface=eth0, Address=00:14:2D:00:00:00, MTU=1500 ]
IPv4 = [ Method=dhcp, Address=192.168.1.205, Netmask=255.255.255.0, Gateway=192.168.1.254 ]
IPv4.Configuration = [ Method=dhcp ]
IPv6 = [ ]
IPv6.Configuration = [ Method=auto, Privacy=disabled ]
Nameservers = [ 192.168.1.254 ]
Nameservers.Configuration = [ ]
Timeservers = [ 192.168.1.254 ]
Timeservers.Configuration = [ ]
Domains = [ ]
Domains.Configuration = [ ]
Proxy = [ Method=direct ]
Proxy.Configuration = [ ]
Provider = [ ]
Hello @yunfeng
Here you have an example (it is for a Rpi but the concept is the same) :
Josep
Ok. Thank you. It seems work. I will do some more tests.
Below what I do. (I have only a little problem is that I can’t see the text I type in the connmanctl mode. but it works)
osmc@rpi2:~$ connmanctl
connmanctl> services
*Ac Wired ethernet_xxxxxxxx_cable
connmanctl> config ethernet_xxxxxxxx_cable --ipv6 off
connmanctl> quit
And I check below ( => IPv6.Configuration = [ Method=off ])
Type = ethernet
Security = [ ]
State = ready
Favorite = True
Immutable = False
AutoConnect = True
Name = Wired
IPv4 = [ Method=dhcp, Address=192.168.1.104, Netmask=255.255.255.0, Gateway=192.168.1.254 ]
IPv6 = [ ]
Domains = [ ]
Provider = [ ]
Hello @yunfeng
Thanks for the feedback. If you can confirm it works, please mark the most suitable answer as solution, please.
Josep
