Does anyone know how can I make this thing to boot from the SD card without using run sdboot commands? Even if persisting the information in the bootcmd the automatic boot does not work for me.
I tried to reproduce your issue at my place but for me this is working fine. If I reset the carrier board, then run sdboot is launched and the SoM is booting from SD Card.
Hi jaski.tx
Which uboot version are you using ?
Could you show me the printenv values, so that I can compare it with my values here ?
I did the same procedure 3 times and no success so far. I have no idea what is going wrong.
Do you have some tips or suggestions to allow me to investigate here? It is good that your setup is working, but I have to fix it on my side.
About the kernel, I am using a Kernel built with Yocto (warrior) but there were no changes and if I do execute the “run sdcard” manually I am able to boot the system. then not sure if the Kernel is a problem.
So far I am trying to compare all uboot variables, so maybe If you can provide the printenv output from your module I can compare it with mine.
Yes. Trying to make it work I fell into the uboot loading problems again. What is the most curious part, I did everything in the same way I was doing before and now it seems to work properly, but using the Toradex Angstron image. Next step will be using my custom image.
Colibri VFxx # print
arch=arm
baudrate=115200
board=colibri_vf
board_name=colibri_vf
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=mmc0 usb0 dhcp
bootcmd=run sdboot; setenv fdtfile ${soc}-colibri-${fdt_board}.dtb && run distro_bootcmd;
bootcmd_dhcp=if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=1
console=ttyLP0
cpu=armv7
defargs=user_debug=30
dfu_alt_info=vf-bcb part 0,1;u-boot part 0,2;ubi part 0,4
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
eth1addr=00:14:2d:5b:ca:be
ethact=FEC
ethaddr=00:14:2d:4b:ca:be
fdt_addr_r=0x82000000
fdt_board=eval-v3
fdt_fixup=;
fdt_high=0xffffffff
fdtcontroladdr=877070c0
initrd_high=0xffffffff
ipaddr=192.168.10.2
kernel_addr_r=0x81000000
kernel_file=zImage
loadaddr=0x80008000
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
mtdparts=mtdparts=vf610_nfc:128k(vf-bcb)ro,1408k(u-boot)ro,512k(u-boot-env),-(ubi)
netmask=255.255.255.0
nfsargs=ip=:::::eth0: root=/dev/nfs
nfsboot=run setup; setenv bootargs ${defargs} ${nfsargs} ${setupargs} ${vidargs}; echo Booting from NFS...;dhcp ${kernel_addr_r} && tftp ${fdt_addr_r} ${soc}-colibri-${fdt_board}.dtb && run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}
pxefile_addr_r=0x87100000
ramdisk_addr_r=0x82100000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x87000000
sdargs=root=/dev/mmcblk0p2 ro rootwait
sdboot=run setup; setenv bootargs ${defargs} ${sdargs} ${setupargs} ${vidargs}; echo Booting from MMC/SD card...; load mmc 0:1 ${kernel_addr_r} ${kernel_file} && load mmc 0:1 ${fdt_addr_r} ${soc}-colibri-${fdt_board}.dtb && run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}
serial#=04967102
serverip=192.168.10.1
setethupdate=if env exists ethaddr; then; else setenv ethaddr 00:14:2d:00:00:00; fi; tftpboot ${loadaddr} ${board}/flash_eth.img && source ${loadaddr}
setsdupdate=mmc rescan && setenv interface mmc && fatload ${interface} 0:1 ${loadaddr} ${board}/flash_blk.img && source ${loadaddr}
setup=setenv setupargs console=tty1 console=${console},${baudrate}n8 ${memargs} consoleblank=0 ${mtdparts}
setupdate=run setsdupdate || run setusbupdate || run setethupdate
setusbupdate=usb start && setenv interface usb && fatload ${interface} 0:1 ${loadaddr} ${board}/flash_blk.img && source ${loadaddr}
soc=vf500
splashpos=m,m
ubiargs=ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs ubi.fm_autoconvert=1
ubiboot=run setup; setenv bootargs ${defargs} ${ubiargs} ${setupargs} ${vidargs}; echo Booting from NAND...; ubi part ubi && ubi read ${kernel_addr_r} kernel && ubi read ${fdt_addr_r} dtb && run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
vendor=toradex
ver=U-Boot 2016.11-2.8.7+g5c2d46b325 (Jun 10 2020 - 16:54:13 +0000)
video-mode=dcufb:640x480-16@60,monitor=lcd
Environment size: 4227/131068 bytes
Then, the only thing I changed was the bootcmd variable.
