After upgrade to 1.4 Beta 1, I can’t get IP address from DHCP server plus I can’t open network configuration window
Debug log:
Done Audio
Loading ENET2...
Done ENET
ENET: Using mac from serial number
The name for the external PHY is KSZ8041
ENET Auto-Negotiation
ENET : Auto-negotiation is on
Loading USB OTG...
Done USB OTG
Loading ESDHC2...
Done ESDHC2
Loading ADC2...
Done ADC2...
Loading ADC1...
Done ADC1...
Loading USB Device...
Loading Display Driver...
No external RTC found
Done Display Driver
Loading PS2...
Failed PS2
Loading Touch...
Done USB Device
Done Touch
+OEMSetAlarmTime(2006/3/12 2:0:0.000)
-OEMSetAlarmTime(rc = 1)
**Exception 'Data Abort' (4): Thread-Id=02230002(pth=8d844120), Proc-Id=00400002(pprc=811a0308) 'NK.EXE', VM-active=01da0002(pprc=8f6d3928) 'udevice.exe'
PC=c0a236f0(enet.dll+0x000036f0) RA=c0a23b38(enet.dll+0x00003b38) SP=d0a7fdd0, BVA=0000000c**
Toradex Bootloader 1.4 BETA 1 for Colibri Built Sep 14 2016
CPU: MVF61 500 Mhz
Flash: 512 MB
RAM: 256 MB
Using ECC Type: 7
Booting from fuses.
Colibri VF61 module version 1.2A
Press [SPACE] to enter Bootloader Menu
Initiating image launch in 0 seconds.
Loading OS Image
Done.
OEMLaunch 80004000
Windows CE Kernel for ARM (Thumb Enabled) Built on Mar 8 2013 at 17:05:33
IMAGE(CE6): 1.4 BETA 1 for Colibri Built Sep 13 2016 15:01:43
Loading EDMA...
Done EDMA
Loading NAND...
Done NAND
Loading UARTA...
Port is used for OS debug!.
Loading UARTB...
DMA: Enabled, ISR: Disabled, Buffer size: 65536Bytes
Done UARTB
Loading UARTC...
Done UARTC
Loading I2C1...
Done I2C1
Loading WKU...
WakeupSources:
SODIMM 43 wake up when toggling.
Done WKU
Loading AC97...
Done AC97
Waiting for flash disk \FlashDisk for 60 seconds
Folder mounted
Loading Audio...
Done Audio
Loading ENET2...
Done ENET
Loading USB OTG...
Done USB OTG
Loading ESDHC2...
Done ESDHC2
Loading ADC1...
Done ADC1...
Loading ADC2...
Done ADC2...
Done Display Driver
Loading PS2...
Failed PS2
Loading Touch...
Done USB Device
Done Touch
Exception 'Data Abort' (4): Thread-Id=023c0002(pth=8d9d1844), Proc-Id=00400002(pprc=811a0308) 'NK.EXE', VM-active=01820002(pprc=8f785000) 'udevice.exe'
PC=c0a236f0(enet.dll+0x000036f0) RA=c0a23b38(enet.dll+0x00003b38) SP=d0a2fdd0, BVA=0000000c
This is what I have when i power up unit with network cable connected.
