Is there a way to add a version number to my torizon OS build? I would be able to boot my OS and then be able to tell what version I am running. I could wait for the build to complete and then edit the image.json file to change the “version” field. I could also add a custom file to /etc/ folder that contains the version number. I could also edit the /etc/os-release file on the board and then “isolate” my change. Is there an officially supported way to do versioning of an OS built with TCbuilder?
Hello! Yes, there are several officially supported ways to add version information to your Torizon OS build using TorizonCore Builder:
1. Specify Version Metadata in tcbuild.yaml
You can add custom version information that will appear in the Toradex Easy Installer by setting the name and description fields in your tcbuild.yaml under the output section:
output:
easy-installer:
local: torizon-core-docker-colibri-imx6-custom
name: "My customized image"
description: "My customized image (description)"
This information will be visible in the Toradex Easy Installer interface to help you identify builds.
More info
2. Add a Version File to the Filesystem
To make the version visible during OS runtime, you can add a file (such as /etc/version) to your image by using the customization/filesystem field in your tcbuild.yaml:
customization:
filesystem:
- changes1/
Inside the changes1/etc/ directory, simply place a file that holds your version string. This file will be part of the deployed OS and can be read at runtime.
How to use filesystem customization
3. Modify /etc/os-release and Use isolate
As you mentioned, you can edit /etc/os-release (or add any file to /etc), and then use the torizoncore-builder isolate command to capture your changes from a target device. This command collects additions, modifications, deletions, and permissions under /etc.
torizoncore-builder isolate --remote-host 192.168.1.117 --remote-username torizon --remote-password torizon --changes-directory changes1
See the isolate command reference
Isolate command manual
4. Use Variable Substitution for Automated Version Insertion
If you want to automate version changes (for example, in a CI system), TorizonCore Builder supports variable substitution. You can declare variables in your config and pass them at build time:
output:
easy-installer:
name: "My Customized Image v${VERSION}"
You then call the build with --set VERSION=1.2.3.
More about variable substitution in tcbuild.yaml
All the above approaches are officially supported for versioning your Torizon OS builds with TorizonCore Builder.
Hey @jzylkin2m,
The AI response gave some good suggestions, does this cover what information you are looking for?
-Eric
Yes I implemented these suggestions and they seem to be working.
A bit late to the party but in our case we used a fourth option - variable substitution in the YAML coupled with a custom kernel argument (osver=v1.2.3-something).
We went this route so that the verison information would be available in the initrd implicitly without needing the root FS to be fully mounted (and we then made a slight tweak to facilitate showing this version on the Plymouth splash screen at boot).
